No keyboard anymore (after uninstalling okboard)
REPRODUCIBILITY: Remove OKboard, after that no normal keyboard anymore.
OS VERSION: 5.0.0.78
HARDWARE: Xperia 10 III
UI LANGUAGE: Dutch
REGRESSION:
  1. Remove OKboard
  2. No keyboard appears anymore whenever one needs to input text.
  3. Rebooting several times doesn’t help.
EXPECTED RESULT: A keyboard to appear to enter text
ACTUAL RESULT: No keyboard appears - makes the phone useless
MODIFICATIONS: I have patches installed but deactivated them to be ready for the big update.
Hello.
I went through ssh in .config and backed up and deleted /okboard and edited /maliit/server.conf which was refering to ok board. I left that file & folder, but deleted its content.
Keyboard is back - problem solved. I can use my phone again!
So there were no other keyboards activated under Keyboards?
Normally this should be possible without a keyboard by selecting/enabling another keyboard layout there.
No, not if you mean from Settings > Text input.
My fix was to just reinstall OKBoard, I only deleted it to free up space for the update. @tvdjolla seems to have found the cause.
So tvdjolla could mark his entry as solution.
For anyone else getting caught out by this, you could also edit the mailit/server.conf file in the Terminal app as it has its own keyboard that remains unaffected by this
I’m not convinced that “i installed a unsupported 3rd-party app, uninstalled it, and my phone broke” is a legitimate bug report on the OS.
Well, I get it, but maliit could be made more resilient against invalid configuration.
At the time of reporting, I had no clue what was happening … I was not complaining, just reporting.
