No internet connection from Virtual Box
Hi all!
I have an issue with a fresh installed IDE, SDK etc. When deploying the apps within Virtual Box my apps do not have internet access anymore. My apps gets a ical file from a server but within the test app in Virtual Box gets an timeout. The file is there and I can access it from my PC.
I assume that Virtual Box is somehow configured wrong but Chat GPT could not help me to set it up correctly.
What should the correct Virtual Box confic look like so that my app can access the internet?
Thanks!
I have no idea why you ask Chat GPT but there is a real documentation here:
You are welcome if you have detailed questions about the Virtual Box documentation.
And please, what is the meaning of “When deploying the apps within Virtual Box
I have it like this:
Hi NIS,
thanks for sharing your setting. Could you be so kind and show me if additional adapters are active? For me Adapter 2 is also active. Adapter 1 has the same confic as you.
Thanks
Sure!
All the same here. I am using a Mac with macOS 12. I guess it is just not compatible any more.
That’s strange. It should work, I don’t know what could be “not compatible”
