hi everyone ive just install 4.4 on the new sony experia 10 great phone and nearly perfect for my needs away from the big tech just a few problems that i have come into if someone could point me in the right direction that would be great
1 I have exported my contacts from both android and ios tried to import in the people app and i just get an error is their anyway to fix this plus when i add a person manually i cant add photo either to them i get an error.
2 Headphone jack does not work when adding my headphones(audio still comes out of speakers ) all working prior to this .
3 whisper fish crashes after i add my number cant seem to find a way to fix
Have you installed the application Positioning - <your region>?
Contacts
If I’m not wrong, there is a bug with contacts and photos. Open your vcf file with a text editor and remove the property PHOTO.
Headphone
There is no sound routed once you plug your headphone in? What happen once your screen is turned off and you plug in your headphone? You screen should wake up. Is it your case?
Hi @owlsy, you can safely remove Google account from your Xperia. Off course it’s always a good idea to make backups of contacts, sms and call histroy, especially before make important changes.
I had no issues AFAIK with the PHOTO property when importing all.vcf file.
But on the upgrade sometimes some contact photos still vanishes. In that case I only reimport. Known bug of minor annoyance.
Also no issues with headphone jack. Other then low volume on all sound outputs including BT. I use workaround in CLI to boost volume on current output which almost always work.
