REPRODUCIBILITY: Every time
OS VERSION: 4.4.0.64
HARDWARE: Xperia 10 III
UI LANGUAGE: Swedish
REGRESSION:
Paired Bluetooth device do not auto connect if Bluetooth was initial disabled. After every system reboot or disabling Bluetooth I have to manually connect the device. Ones that is done, auto connect works fine until next reboot or disabling Bluetooth.
Xperia 10 III with bluetooth disabled and one already paired Bluetooth device turned off.
Activate bluetooth on phone
Turn bluetooth device on
Wait for connection
Bluetooth device gets connected to phone
Bluetooth device do not connect to phone
Only mod that is related to bluetooth is Patchmanager patch “Restart BT in SF Utilities” but disabling it does not help.
Yesterday i had the same issue with my 10 Mk3 and Huwei AM-61.
I tried to disable and enable BT 5-10 times. No luck.
I didn’t try to use “Utilities”, I used “Forget this device” and pair it again.
If someone has a bluetooth device pairing automatically with his X10 III, is it possible to share a screenshot of the device’s settings? It’s under Settings->Bluetooth->Long press on working device, show device information.
I’m curious if a working device (one pairing automatically) has the profile AVRCP or not.
This seems to be happening only with BT Headphone devices (as mentioned before, happens with my Freebuds 3 and my Creative speakers).
My Amazfit GTR is auto-connecting every time, even after reboots. I never had to manually connect it.
(Or maybe Piggz is “handling” the matter in the background with his Amazfish app).
This is a known issue. The Bluetooth device name is lost after a reboot. Workaround is to set again the device name at every reboot. This is also the reason for which I am not using my X10III as a daily driver.
I paired with my partners Subaru BRZ and have connected successfully. I then rebooted my phone to test, after reading here and it autoconnects to the car without issue.
update:
When restarting the car/repairing, the sony previously playing will restart but the counter will continue to elapse thus the time elapsed for a song is longer than actual song length.
I wish I had problems like no auto-connect. I can’t pair the damn thing with my car kit at all (as the only smartphone that I’ve ever tried with it).
