REPRODUCIBILITY: Almost every time phone is connected to car
OS VERSION: 4.5.0.21
HARDWARE: Xperia 10iii
UI LANGUAGE:English
REGRESSION: No
No audio when connected to car hansfree. The car handsfree kit can be used to initiate an out going call, answer an incoming call and terminate a call but there is no audio.
Connect phone, which usually happens automatically
there’s this problem with bt. Try to switch the car kit into music first, and after connecting the phone, try to play something, once working only then try to make a call, it should work.
I have the same problem for about 3 years, with both the Xperia XA2 and the Xperia 10 II. Both are dual sim and the problem only occurs with car stereos (verified in 4 different brands: Bosch, Pioneer, Alpine, LG). With the Xperia 10 II, I often have to turn off the second sim, turn it back on and restart the phone’s Bluetooth system. The same phones, with the same car stereos, don’t give any problems if they have Android and not Sailfish.
in my case the address book works, I can initiate a call over the car’s handsfree device by using the voice commands for the handsfree device thus accessing the address book but there is no ring tone and no audio in either direction. I have to switch the phone from the car kit to the phones speaker to be able to communicate.
I disabled the phone connection (not the notifications connection) to my Amazfit watch. There are two Bluetooth connections on the watch. Since then I have been able to connect reliably to the car kit. I still need to do a Bluetooth restart from the Utilities option in Settings to get the phone to connect sometimes (usually after a phone restart or after Flight Mode has been in use), but otherwise it works OK.
I suspect my problem was the audio was being routed to the watch even though the car kit initiated the call.
