NFC doesn't work any longer
BUILD ID = OS VERSION (Settings > About product): 4.4.0.58
HARDWARE (XA2, X10, X10 II, …): XA2 Plus
UI LANGUAGE: French
Nfc activated in settings, no reaction when near nfc tag.
Activate Nfc in settings
  1. Put a nfc tag near the nfc reader
Phone vibrates
None
(Please ALWAYS attach relevant data such as logs, screenshots, etc.)
In ncf logger : conitnuous flow of messages:
nci: Notification 0x01/0x23 is ignored in RFST_DISCOVERY state
binder: android.hardware.nfc@1.0::INfcClientCallback 2 sendData
data, 3 bytes(s)
61 23 00 a#.
Could you send more data provided by the app NFC Logger (available on Storeman)?
After reboot, these messages have disappeared and NFC works again.
Same here with XA2 4.4.0.72, but unfortunately it doesn’t wirk better after reboot.
NFClogger return same message in top of topic…
Thanks for the original report @phklrz, and @mkz for sharing your experience. It’s unfortunate that the reboot didn’t address the problem for you. Given this, I’ve created an internal report about it and tagged it here as “tracked”.
Same here with XA2 DS running 4.5.0.21 and 4.5.0.24. Device won’t read NFC tags even after a fresh reboot.
Perhaps this topic should no longer be marked Solved?
Log from NFCLogger:
2023-09-20 12:45:20.378 binder: android.hardware.nfc@1.0::INfcClientCallback 2 sendData
2023-09-20 12:45:20.378 > data, 3 byte(s)
2023-09-20 12:45:20.378 > 61 23 00                                            a#.
2023-09-20 12:45:20.378 nci: Notification 0x01/0x23 is ignored in RFST_DISCOVERY state
## Log truncated:
## The previous four lines keep repeating every 650 ms or so.
## Nothing else is logged until I toggle NFC off from the top menu.
2023-09-20 12:45:36.076 NFC disabled
2023-09-20 12:45:36.079 binder: Waiting for NCI state machine to become idle
2023-09-20 12:45:36.080 nci: < RF_DEACTIVATE_CMD (Idle)
2023-09-20 12:45:36.080 nci: Next state RFST_DISCOVERY -> RFST_IDLE
2023-09-20 12:45:36.080 dbus-neard: Power requested: off
2023-09-20 12:45:36.080 dbus-neard: Powered: off
2023-09-20 12:45:36.080 dbus-neard: Enabled: false
2023-09-20 12:45:36.151 Wrote /var/lib/nfcd/settings
2023-09-20 12:45:36.152 < 21 06 01 00                                         !...
2023-09-20 12:45:36.162 binder: android.hardware.nfc@1.0::INfcClientCallback 2 sendData
2023-09-20 12:45:36.162 > data, 3 byte(s)
2023-09-20 12:45:36.162 > 61 23 00                                            a#.
2023-09-20 12:45:36.162 nci: Notification 0x01/0x23 is ignored in transition
2023-09-20 12:45:36.194 binder: android.hardware.nfc@1.0::INfcClientCallback 2 sendData
2023-09-20 12:45:36.194 > data, 4 byte(s)
2023-09-20 12:45:36.194 > 41 06 01 00                                         A...
2023-09-20 12:45:36.194 nci: > RF_DEACTIVATE_RSP ok
2023-09-20 12:45:36.194 nci: Current state RFST_DISCOVERY -> RFST_IDLE
2023-09-20 12:45:36.194 dbus-neard: Mode: 0 (Idle)
2023-09-20 12:45:36.194 dbus-neard: Polling: false
2023-09-20 12:45:36.195 binder: Closing adapter
2023-09-20 12:45:36.205 binder: android.hardware.nfc@1.0::INfcClientCallback 1 sendEvent
2023-09-20 12:45:36.208 binder: > CLOSE_CPLT
2023-09-20 12:45:36.210 binder: Waiting for close to complete
2023-09-20 12:45:36.233 binder: Power off
2023-09-20 12:45:50.489 Name ':1.225' timed out
Same as above for my XA2 with Sailfish OS 5.0.0.73.
National IDs in some European countries now basically require you read data off of them through NFC in order to be able to interact with public institutions.
That is unrelated to the original question which was about NFC not working at all. Android applications have never had access to NFC on Sailfish (maybe in the future, but not yet).
Sorry for confusing you, but my message above has nothing about Android… Same as above, I’ve tried reading NFC tags on my XA2 (even after a reboot) and checked the logs with NFCLogger from OpenStore. All this on latest Sailfish OS.
My intention was to try the recently-published native NDEFined app to see if it helps with reading data off “digital” IDs: NDEFined | OpenRepos.net — Community Repository System
Version 0.8 should identify the tag as a digital ID card or passport, but it won’t read any other data from it.
Sorry about that. My experiences with identification-related tasks and NFC is with Android applications.
I’ve installed Android app ‘Freja’ (ID-app) and used it for NFC-scan my passport, and it worked fine. The app works great. Sony Xperia 10 III SFOS 5.0.0.72.
