OSVERSION: 5.0.0.55
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.33 - aarch64
REGRESSION: not specified
With an SFOS Nextcloud account, if you set notifications to on, then they only work once after a reboot. From that point on notifications no longer work.
A working Nextcloud account
set up a Nextcloud account
set Nextcloud notifications to on
No notifications are displayed
Reboot phone
Outsanding notifications are didisplayed
No further notifications are then ever displayed
EXPECTED RESULTS:
Nextcloud notifications are displayed whenever they are generated
ACTUAL RESULTS:
Notifications are only displayed once immediately after a reboot and then never again
Patchmanager: yes
OpenRepos: yes
Chum: yes
Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.13+git2
Can you please see if there is a buteo-oopp-runner job running and never finishing?
I have had this phenomenon a couple of times where some kind of configuration issues caused buteo to never finish the sync, and hence never start another scheduled one.
I also received no notifications from my Nextcloud instance. Is it required to have push notifications enabled on the server side for them to work, or should it follow the sync interval set up in the Nextcloud account settings?
