Network settings for SMS and voice calls for Bouygues Télécom and co (Fr)
I had difficulty sending SMS messages (they took a long time to send) and incoming calls were sometimes choppy, even in areas with excellent network coverage. I can’t explain why, but changing the Mobile Network settings solved the problems :
In Settings / Mobile network :
Normally, there’s no need to restart the phone.
Note that Cdiscount Mobile uses the Bouygues Télécom network, so the procedure could potentially also work with the source operator, as well as operators using the same infrastructure.
Hello, I have the same problem here with LaPoste mobile. It didn’t work at all with all your advices…I even change the position of the SIM card….https://forum.sailfishos.org/t/the-network-logo-is-blinking-and-im-unable-to-send-text-messages/28965
La Poste Mobile is a French virtual mobile telephone operator using SFR’s network infrastructure until the end of 2026 for existing subscribers and from September 29, 2025 on the Bouygues Telecom network for new subscribers.
See also: Assistance La Poste Mobile
