REPRODUCIBILITY (% or how often): 99%
BUILD ID = OS VERSION (Settings > About product): 3.4 and 4
HARDWARE (Jolla1, Tablet, XA2,…): x10+
UI LANGUAGE: german
after almost every call, i get network connection error for est. 10 seconds.
operator o2 in germany
make a call
end it
wait for the connection to reestablish
no network connection error
IIRC with 2G you can only have voice or data, not both.
In my case I usually only have 2G enabled and I see this error too after making a phone call.
I am using Vodafone in the Netherlands through a reseller (HollandsNieuwe).
Even if it was the case, why would it result in that message?
But it is not the case (at least not in general):
My semi-professional guess is that the phone is booted off the network and told to reconnect in LTE when you hang up.
…and that takes a little bit of time, and the interaction between the modem and ofono can’t quite convey that this is normal behaviour. I see this too sometimes.
And what do i mean with “booted off” - i mean release with redirect. As this is not based on measurement reports, the mapping of coverage areas is approximate, and could end up having your phone look for an LTE cell that is not strong enough. Not sure what this looks like from GSM/2G (and too lazy to look at the spec) so basing this off UMTS/3G - there is bound to be something similar.
@mankir
What technology shows when you are in the call, and where do you end up afterwards?
(And do you have a lower preference than LTE in settings?)
And as there is no VoLTE support, you would always be on 2G during calls then.
So i think the network throws you out, back to LTE, when you hang up - possibly with the wrong parameters.
So what might Jolla be able to do about it? Possibly detect it and/or suppress the error message, not much more probably.
I think there is something for Jolla to investigate. I suggest this Audible tone after ignoring call is related. MEO(Altice) in Portugal…
A test call went from 4G to 3G during the call and afterwards back to 4G, but this call, with no error…
