If anyone has a bit of time, I’m stuck debugging Videoworks | OpenRepos.net — Community Repository System
I don’t have a 4.1 device yet. I just need to know if the app opens video files on 4.1
I can do it on a Xperia 10 ii.
After installing the aarch64 version, it doesn’t manage to load the video files.
Which log file could I send you to help?
Doesn’t seem to work for me. pulley/picker behave normally, but after selecting video, it just goes back to main screen with no video …
That suggests ffprobe is not there. hmmm. Terminal output would be great:
# which ffprobe
/usr/bin/ffprobe (hopefully)
Also, which ffmpeg, please.
if that’s there:
rpm -q --whatprovides /usr/bin/ffprobe
Thanks!
Both ffmpeg and ffprobe seems to be in the (not installed) package ffmpeg-tools.
Ah! Odd, I thought they were always installed. Hmmm. Is this a bug or ‘progress’?
Thanks!
Could my willing bug squashers please try to install:
zypper install ffmpeg-tools.
And let me know if that does it. Hmmm.
Thanks again!
That seems to do the trick.
Does that mean that pre-4.1 installs (seemed to) have these installed by default, but 4.1 doesn’t? Anyway, isn’t it as simple as adding or modifying the Requires: line in the spec file?
Yes, ffmpeg-tools was installed to support the web browser as explained to me by vige.
Sadly, this is not a Requires that’ll work in harbour, but it should work for chum/open repos.
For me too. It’s now able to play the loaded videos
confirmed - working now …
Thanks guys. I’m rebuilding the 4.x series an uploading.
Just a note, the last 0.3.6.1 build had broken saving. That’s fixed, on openrepos, with 0.3.7.1.
