Hi all, as per the title, I need a paste of the entire file found in /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml for Xperia 10 ii latest OS version ending 68.
I committed the cardinal sin of NOT backing up a copy of the file, then ballsed something up because of artifacts presented by nano editor!!
I don’t really want to reinstall lipstick so just the file would be good!, thanks
Probably not the propper way…
Copyright (c) 2015 - 2020 Jolla Ltd.
Copyright (c) 2020 Open Mobile Platform LLC.
License: Proprietary
import QtQuick 2.6
import QtQuick.Window 2.1 as QtQuick
import Sailfish.Ambience 1.0
import Sailfish.Silica 1.0
import Sailfish.Silica.private 1.0 as Private
import org.nemomobile.lipstick 0.1
import “…/backgrounds”
Item {
property alias ambience: ambience
property alias homeWallpaperItem: homeLoader.item
property alias applicationWallpaperItem: applicationLoader.item
property alias applicationBackgroundOverlayImage: appBgOverlayImage.textureProvider
property alias transformItem: ambienceInfo
property alias dimmer: homeBackground
readonly property bool exposed: homeLoader.item || homeLoader.replacedItem
readonly property alias animating: homeLoader.animating
signal transitionComplete()
signal rotationComplete()
Component.onCompleted: Ambience.create(Ambience.source)
HomeBackground {
width: wallpaperItem.width
height: wallpaperItem.height
ApplicationWallpaperLoader {
visible: false
transitionEnabled: true
HomeWallpaperLoader {
visible: false
transitionDelay: wallpaperItem.visible ? 200 : 0
onTransitionComplete: wallpaperItem.transitionComplete()
BackgroundTexture {
visible: false
AmbienceInfo {
url: Ambience.source
Item {
anchors.centerIn: parent
width: Screen.height
height: Screen.height
rotation: Lipstick.compositor.topmostWindowAngle
Behavior on rotation {
SequentialAnimation {
RotationAnimator {
direction: RotationAnimation.Shortest
duration: 200
easing.type: Easing.InOutQuad
ScriptAction {
script: wallpaperItem.rotationComplete()
opacity: visible && homeLoader.animating && ambienceLabel.text !== "" ? 1.0 : 0.0
Behavior on opacity { FadeAnimator { id: infoAnimation; duration: 300 } }
Label {
anchors {
left: parent.left
leftMargin: Theme.horizontalPageMargin
right: parent.right
rightMargin: Theme.horizontalPageMargin
bottom: parent.bottom
bottomMargin: ambienceInfo.height / 8
color: ambience.highlightColor
text: ambience.displayName
font.pixelSize: Theme.fontSizeHuge
font.family: Theme.fontFamilyHeading
horizontalAlignment: Text.AlignHCenter
elide: Text.ElideRight
maximumLineCount: 5
wrapMode: Text.Wrap
karry
25 July 2022 18:18
3
zypper install cpio
zypper download lipstick-jolla-home-qt5
mkdir /tmp/rpm
cd /tmp/rpm
rpm2cpio /home/.zypp-cache/packages/jolla/non-oss/aarch64/lipstick-jolla-home-qt5-1.24.16.3-1.9.9.jolla.aarch64.rpm | cpio -idmv
and you have it there: usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
Thanks guys, more so to @plemil ~ it was a just a few lines I’d somehow deleted, but now I am up and running again!
