REPRODUCIBILITY:
OS VERSION: 4.5
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION: No
Since the latest update of Mobile BankID app for Sweden it is now needing Bluetooth to connect to nearby devices during setup mode.
Sailfish is unable to use nearby devices from what I can see so I can never complete the setup.
I did also try using another mobile and installing a version prior to this update but that didn’t work either. And anything too old displays a message that the app is too old.
I also tried physically pairing the mobile via bluetooth with the other mobile as you need another to install then scan a QR code on the other mobile to set up mobile bankid on a new device.
Another mobile and a banking app in Sweden to setup mobile BankID on a new device.
- Open banking software on a mobile
- Add a new bankid
- Go thru the process then scan the QR code with the new mobile ie sailfish os mobile
Complete the setup process by finding the new device via nearby devices. This is a new security feature.
Unable to complete the process as it cannot find the sailfish mobile via bluetooth nearby devices.
