Native Spotify on SailfishOS (with Hutspot/Librespot)
I was also thinking about that.
I wonder why that isn’t installed per default?
Thank you! Now hutspot works after installing mpris.
I needed to remove –username parameter from librespot command to get it work without re login every time I starter it/hutspot start it.
New Jolla phone (2026).:blush:
Do you know if it is possible to listen to podcasts on hutspot from spotify?
Huh huh :slight_smile: I follow this thread and try to build picture, is this still valid way tryout native Spotify :)?
Yes it is! I try to update it regularly with the latest instructions
If the instructions don’t work, feel free to tell your problems here :slight_smile:
So happy that it finally kind of works on my JP26. I have to start Librespot via terminal but that’s ok. Not too much effort. In Hutspot I can search for and listen to music but I didn’t find out how to follow or save Albums or Artists. No matter if I check the star icon, all libraries (My Stuff, Good Stuff, etc.) indicate “nothing found”. When I long press a title and chose Add to Playlist, I can select from all of my Playlist that I configured in Spotify but I have no idea how to play them. I’m a little lost.
I have that sometimes when it is very slow to load. After waiting a bit or refreshing the page (by navigating to another page of My Stuff and then back), it normally loads eventually. Can you try that?
Change to qobuz, then you have a native option and the artists get 12 times the money spotify pays out :wink:
Can you please stop advertising another platform in a thread that is about helping people get Spotify running. If someone wants to use Qobuz, he or she wouldn’t be in this thread. This is not really helpful for people having problems with Spotfiy.
P.S.:
As you can see, Spotify also has a native option :wink:
Thank you for your help. Unfortunately waiting and/or refreshing don’t help. Nothing is coming up. I was wondering if this could be a language issue. All other Spotify clients and the Account are set to German but I always use Sailfish in English. The word for “Library” is different but ”Playlist” is also used in German. As said before, when I use “Add to Playlist” they are all listed.
Thanks a lot nas! This issue of the qt plugin is still there with SFOS 5.2 on a Jolla Phone2026! I was getting crazy with the white screen appearing to me every time I tried to open the app. This solved the issue!!!
Maybe because of the different Sailifsh language. You could try setting Sailfish to German and see if it works. But using Hutspot in another language than English shouldn’t be an issue, I myself only ever used it in German
Thanks again, Nis! It is interesting to use SFOS in German for the first time but it has no effect for Hutspot. Everywhere “Nichts gefunden”. In Terminal I found:
[2026-09-16T08:25:53Z WARN libmdns::fsm] couldn’t par se packet from [fe80::5256:a8ff:fe07:3ac%34]:5353: que ry type 47 is invalid
Is there any connection to my issue?
After struggling for a couple of weeks I can confirm that you don’t need the
--username &USER_ARG
you just need the
--enable-oauth
and now it works PERFECTLY!!!
Thanks @blackish
That’s good to know, I will update the Wiki accordingly. Thanks!
@guangel Could you maybe add your device and version to the “Working versions” here? Use Librespot to play ... | SailfishOS community wiki
Does anyone here already know about Spotilol? A native version could be useful.
Well, it works, but instead of starting librespot on the commanline, start hutspot separately and going through the authentification process each time I want to usr it, I’d rather appreciate a more simple way to access the content. And I have to admit, that I really miss a fullword search for content, albums or artists.
But besides that - great work!
I’m not really sure what you mean. The normal process should be Start Hutspot → wait until Librespot appears → select it as active device → play music.
If Librespot doesn’t start automatically with Hutspot, you have configured something wrong and need to enable that in Hutspot’s settings.
If you need to re-authenticate Librespot every time you use it, there might be something wrong with your caching. If you tell me how you start Librespot (exact commands), then I can help you debug.
If you need to re-authenticate Hutspot every time you use it, there might either be something wrong with Sailjail or you have maybe blocked Cookies for Spotfiy? You can also try “Log in using Browser” in Hutspot’s settings and see if that helps
