I am working on a native Matrix client. I am aware there are others working on this, but having alternatives is good. It is a hobby project, so progress will be step by step. I am looking for additional test people. Please react on this message and I will include you in a matrix room for this matter.
Following is working:
initial logon with password, afterwards with token
device verification based on emoji
sending/receiving messages and images, in plain and encrypted
encryption is using matrix / vodozemac library and data on device is protected via sailfish crypto/secrets library
Hello, don’t take this the wrong way, just curious: what didn’t you like about the alternatives available to the point of wanting to create another app?
Fair question It started one and a half year ago when my Android phone was out of support and I found Sailfish as European alternative. As I also wanted to switch to an alternative for Meta, I found Matrix. At that point the only Matrix client on Sailfish was Sailtrix, which asked to many access rights. I thought, let’s make a client on my own and contribute to the community I underestimated it a bit, so it took a long time until things got working properly. AI helped, but also put me back as it doesn’t help you to understand everything properly and generates a lot of code, so I kicked out a lot again. In the main time other clients popped up for Sailfish. I was impressed, because they are more feature rich then mine, so I was a bit discouraged. But I decided to proceed, alternatives are good and for me it helps me to understand better developers and system engineers working on real life cases. I look as little as possible to the alternatives to avoid copying, and use the app daily, also encouraging friends and colleagues to start using Matrix
Actually, we had also been using Hydrogen for a while at that point. The real game-changer was xmatic, though (link). It is under very active development and almost feature complete (even more so than nheko on the desktop).
I do not wish to discourage you. On the contrary, we need all the gifted coders on SFOS that we can get. Alas, wouldn’t it be closer to the open source spirit to collaborate and contribute to a project so it will eventually be the best app for the job fulfilling all your needs?
