I just received the new Jolla phone today and am fairly excited! I always wanted a linux phone, so I am looking forward to what this plattform will become in the long term. I realize that this phone might not be perfect yet, but I seem to encounter a lot of crashes. The whole phone reboots every few minutes (when i set it down), and most (android) apps also crash constantly. I am not sure if I am doing something wrong. I tried to install native apps, but there is no install button in the Jolla Store. I dont have a SIM card installed, if that makes a difference. Not sure how to proceed or how to debug this issue, any advice?
Strange, nobody else is reporting crashes - maybe a hardware defect?
If you expect buttons, maybe re-take the getting-started guide/app.
I would try pure native experience for some time to see if the crashes persist or stop. That way you can figure out if it is purily related to your android app support or a more systemic problem.
For going native you should get not only the Jolla Store but install also Storeman (for openrepos) and Chum. The latter two are community based stores and a lot of apps are only there.
Rubdos created a great small tutorial for getting Storeman and Chum up and running. All 3 stores work slightly differently. Please keep in mind that some important options are accessible only via that Sailfish OS unique scrolling gesture. Have a look at the phone tutorial for how to do that.
The phone does a lot of software installs when you begin using it. As a longtime SFOS user, that was a surprise. Otherwise, though, it’s been quite stable for me.
As far as the Jolla Store goes, you need to look for the pull-down menus. Also know that some really old apps won’t install on the J2. Only the aarch64 apps can be installed.
Erm… no? What kind of installs are you talking about?
If you are talking about the first boot setup asking what Jolla apps to install near the end of the experience, that has been there since the launch of the first Jolla Phone?
Mine does not crash, I only experienced a couple of lockup of the whole phone when using the native browser.
Some Android apps indeed do crash, but that’s because of incompatibilities (eg they are designed to check for root, they look for some Google-specific stuff that MicroG cannot (yet) provide, etc.) but most work fine.
The phone rebooting points to a hardware issue unfortunately.
I am not a Jolla Phone user yet, but I did use a Jolla C2 and I never had a single reboot or system freeze on it.
However, I wasn’t able to set it up to work on the 4G network, only on 2G, because my internet provider no longer supports the 3G network — which would have also been enough for me for browsing the internet.
Interesting. I realized that I needed to use the pull down menu to install software, thats on me, and thanks for pointing it out! The system seems to have settled down a bit and seems somewhat more stable. Android apps still crash after a short time (or are closing themself ?). but also native apps, eg. the browser.
I just observed that the phone shut itself down while being in standby. The phone is on my desk, I quickly saw the “Auf Wiedersehen” (Goodby) message. Is this a bug or a power saving feature? The battery is at 62%
That’s definitely a bug or HW issue. Is there anything in logs when app crash occurs?
Reflash might help but AFAIK images are not avaliable for your phone.
Do you have many apps open when they crash? What kind of apps and where you installed them from?
A power saving feature (self shut down) might kick in, but only at very low levels of battery, around 2-5% I would say, so that is definitely not normal.
I dont have many apps open (I cant, as they keep closing), i installed some from Aurora, F-Droid and Storeman, maybe 10 or so. But the instability began when I first started the phone, not when i installed apps. I have Microsoft Exchange, Predictive text input, Android-App Support as Extensions, which were the default I think
If it already began after first usage you should contact zendesk, assuming a HW failure.
You could try to reset it and start all over. But this is a serious action and you should what you are doing.
I will try a reset and avoid extensions and android apps and see is the issue persists
Please check if /sys/fs/pstore/ contains anything after such crash or strange power off.
I have had a couple of crashes where the whole phone reboots during the first month of using my new Jolla phone. These seemed to be related to the stock browser, but I didn’t investigate any further.
Now this topic inspired me to try and do some further testing. I was able to make the browser crash and reboot the whole phone again. The crash happened when I had this page https://yle.fi/a/74-20238112 open and a video on it playing when display went to sleep. Then phone rebooted after it had been in sleep for a couple of minutes. Earlier the phone rebooted with this same page open and browser running in the background while phone was in sleep. It happened even two times in a row after which I seemed to be able to pinpoint the issue relating to the browser. First time this happened phone was charging. This has also happened with another website open. I haven’t had many other applications open when these crashes have happened.
As of now I’m not able to reproduce the issue reliably, but here are some logs of the latest crash today: /sys/fs/pstore/console-ramoops-0 - Pastebin.com
Edit: I noticed that the earlier attached logs are actually from July. Very much appreciated if someone can point me towards some logs that I could fetch to help investigate this further.
[root@JollaPhone2026 pstore]# last reboot head -5
reboot system boot 6.12.38-4k Fri Aug 14 00:22 still running
reboot system boot 6.12.38-4k Thu Aug 13 14:40 still running
reboot system boot 6.12.38-4k Wed Aug 12 23:24 still running
reboot system boot 6.12.38-4k Wed Aug 12 16:17 - 23:23 (07:06)
reboot system boot 6.12.38-4k Wed Aug 12 01:41 - crash (14:35)
[root@JollaPhone2026 pstore]# last reboot | grep crash
reboot system boot 6.12.38-4k Sun Aug 2 20:54 - crash (00:36)
reboot system boot 6.12.38-4k Sun Aug 2 01:19 - crash (19:34)
reboot system boot 6.12.38-4k Sat Jul 25 17:44 - crash (21:42)
reboot system boot 6.12.38-4k Thu Jul 23 01:21 - crash (1+00:51)
There have always been many things to install, but not as many things spontaeously installing as on the J2.
Well Jolla has made a new app and added more AAS stuff to be able to install from the first boot setup since the early days of SFOS. Can’t remember the exact point when Jolla made the Voice Recorder app, and these days if I remember correctly, you can choose to install microG, Aurora Store, F-Droid and maybe even the new BT Bridge as part of the setup process instead of needing to install so much stuff from the Jolla Store as a first thing you do. Who knows, maybe in the future the setup for Jolla C3/JP-3901 can ask, if you want to install NFC Bridge and some native wireless payment app.
