As other threads/posts I read here have mentioned, Apps like MS/Google Authenticator among others are now widely used by major corporation to enforce MFA.
So hope a push for MFA in v3 release is included and/or an alternative is added, but I know with Microsoft networks/corp.net you cant sign on unless using MS Authenticator as MFA app.
That’s one up high in the agenda IMHO that should roll out as a priority.
With corporate microsoft accounts, there is an option to use regular OTP 2FA. You are not forced to use microsoft’s app, although the option is a bit hidden by using a small link next to a flashy button.
At least, this was true when I needed it a couple of years ago, although I think still windows 11 era.
Why? Why would someone that chooses SailfishOS want to use those apps, if there are multiple native alternatives? And why would they want it so much, to carry a second smartphone around? This statement baffles me.
I’m using FoilAuth for Microsoft Teams login in the company, and it works!
It has also been tested with:
Nintendo Account
Schulmanager Online
Google
Synology NAS
Synology Account
Strato Webhoster
Amazon
eBay
GOG
Microsoft
Kickstarter
Slack
If you have a secondary or fallback SFOS device, don’t forget to secure your 2FA tokens on that unit by scanning and importing the QR code, for example. Printing it out and placing it in a secure location should also work (not tested).
You can also simply scp the relevant directories over. I did this last time I broke the screen on my phone which has ruled out using QR codes. One could also create a .tar.gz and store them somewhere as backup.
Organization can setup their MS 2FA how they like from multiple options. They can allow/block the usage of those 3rd party apps, have OTP, TOTP, enable SMS or even calling as a 2FA.
None of the batches has any SW goals, for good reason.
SFOS has been around and usable for 12 years - you make it sound like some Kickstarter project that will promise random stuff they cannot deliver to drive sales.
So you want to switch away from big tech, and the install their locked-down apps the first thing you do. Come on.
Standard and open MFA works perfectly fine.
So today the list of “essential” apps is one, tomorrow it is two - and before long nobody can use any alternative OS ever again.
Passkeys are not MFA. They are just a lock-in managed password where the password manager pinky-promises to have biometrics - no actual enforcement possible.
