I’ve only had the phone for 4 hours, so it’d be very weird if there was dust buildup already.
BTW, re Authenticator: make sure MicroG is installed and that all self-checks pass. Notifications will work then, though I still suggest you unlock the phone when you expect a notification, otherwise the code prompt sometimes doesn’t appear (even though you tapped the notification).
Wait what, you have some easily reproducible way to use MS authenticator? I have all self-checks tapped from Microg, even gave permission to display over other apps. I don’t know how to test if all of those self-checks pass?
When ever I try to activate the passworless sign-in request thingy it demands to set screen lock for android side which doesn’t work. Do you have some tip for that?
Ah, I never tried setting up passwordless. However, since it requires android screen lock, this won’t work on J2 (yet?), but should work on Xperia 10 III, as long as you install appsupport-lockscreen from Storeman, and follow the instructions to enable Android screen lock.
What does any of those profiles look in the MS authenticator? And just to check, you get those number verifications even to Jolla phone after entering the password in PC?
Fuck man, you are genius! So for others, when you get initially your MS account added to the authenticator and are in screens seen upper messages, choose “Set up 2-step verification”. This will then ask you to sign in, do it. After it will give you some page, continue. After it will tell you that your hardware doesn’t support passkey, skip. In next screen it asks you to set lock screen pin, from this screen go back from arrow at top left corner. With this way you get what most of us are looking here!
@filip.k could you move these messages regarding the MS authenticator between me and @ender to some thread that better fits for this? At least I finally have the working procedure to setup it properly! Going to sleep super happy Will tell everyone about this tomorrow at work
I added the accounts by going to https://mysignins.microsoft.com/security-info and clicking “Add sign-in method” there, selecting “Microsoft Authenticator”, then scanning the QR code.
For sure you can if admin ha enabled it. My school account can only be authenticated through MS 2 step verification. Now I don’t need to have second phone for that!
I’m very unpleased by my school desicion and contacted about this problem but I can’t do much more… waiting brighter future….
So for those that might need the 2-step verification also, here is guide as well I remember it:
login to your MS account My Sign-Ins with PC → go to security →Add sign-in method → Select Microsoft Authenticator →Scan QR code.
At this point it will then give you some nice screen within you MS authenticator app. It is important to choose to add “Set up 2-step verification” if it was possible, if not just continue. Do not choose the “Set up Passwordless sign-in requests”. At first it will tell you that you can’t create a passkey, press skip.
Now you are in a screen that tells you haven’t set lock screen pin. From top left corner click the back arrow. With this I was able to enable the 2-step verification and I hope you too!
