BUILD ID = OS VERSION (Settings > About product): 4.3.0.12
HARDWARE (XA2, X10, X10 II, …): XA2
UI LANGUAGE: English UK)
Upgrading my phone to 4.3.0.12 results in an unstable internet connection that keeps on saying “connecting” and “Limited Connectivity” in a loop.
The internet connection is therefore unstable and I can’t browse the internet properly .
I thought this might be an issue with the setup of my device, so I reset my phone and upgraded it up to 4.3.0.12 without changing any settings or installing any apps.
I can confirm that the version prior to this doesn’t have this issue.
This issue has been seen after updating to latest version with my original software setup on the device and also after the reset.
Some other information:
Before updating to 4.3.0.12 I saw “Remove or revert the following packages, as they may cause problems during update”
This message was shown both times before I performed an update to 4.3.0.12.
The list of software to remove was very long.
The mobile network is UK EE, I have tried this around several sites around London and Manchester.
The hardware is an Xperia XA2
A (blurry) video showing this fault can be seen here: https://youtu.be/qe6Rx6KYHDM
There is also common random vibrations that the phone does frequently
Upgrade to 4.3.0.12
- Upgrade to 4.3.0.12
- Observe bad 4G
Stable 4G connection as per the last version
See SailfishOS update to 4.3.0.12 unstable Internet - YouTube
Watch SailfishOS update to 4.3.0.12 unstable Internet - YouTube
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
