REPRODUCIBILITY: 100%
OS VERSION: Sailfish OS 4.4.0.72 (Vanha Rauma)
HARDWARE: Xperia XA2 h3113
UI LANGUAGE: DE
REGRESSION:
Mobile ID (version 3.007) does not work
ServiceProviderName: upc ch
Mobile ID: Version 3.007
- go to My Mobile ID Login
- in dashboard go to Test Mobile ID
Ok
The test was successful
Error
The test was unsuccessful
Your Mobile ID test run was unfortunately not successful.
Patchmanager: no
OpenRepos: yes
Chum: yes
Other: no:
Home Encryption: enabled
Extract from journalctl
Nov 04 15:40:32 XperiaXA2 simkit[13408]: [D] unknown:0 - /simkitagent/ril_0 - PlayTone: "positive-acknowledgement" : "" ( 0 ) "file:///usr/share/simkit/audio/positive-acknowledgement.wav"
Nov 04 15:40:33 XperiaXA2 invoker[5817]: WARNING: An inactive plugin is misbehaving - tried to show a window!
Nov 04 15:40:33 XperiaXA2 invoker[5817]: WARNING: requestActivate() called for QQuickView(0x6b33f0) which has Qt::WindowDoesNotAcceptFocus set.
Nov 04 15:40:34 XperiaXA2 simkit[13408]: [D] unknown:0 - /simkitagent/ril_0 - responseOK
Nov 04 15:40:34 XperiaXA2 kernel: binder: 6488 RLIMIT_NICE not set
Nov 04 15:40:34 XperiaXA2 simkit[13408]: [D] unknown:0 - /simkitagent/ril_0 - replyErrorEnd
Nov 04 15:40:34 XperiaXA2 lipstick[5048]: [W] unknown:336 - file:///usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml:336: TypeError: Cannot read property of null
Nov 04 15:40:34 XperiaXA2 mce[2192]: tklock.c: tklock_dbus_notification_end_cb(): notification end from name=:1.256 owner=:1.256 pid=13408 uid=100000 gid=996 priv=1 cmd=/usr/bin/simkit
Extract from ofono.log
2022-11-04 15:06:05.129 slot1> 0000: 01 00 00 00 f1 03 00 00 63 00 00 00 00 00 00 00 ........ c.......
2022-11-04 15:06:05.129 slot1 0008: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........ ........
2022-11-04 15:06:05.129 slot1 0018: ff ff ff ff 1e 00 00 00 55 00 00 00 0a 00 00 00 ........ U.......
2022-11-04 15:06:05.129 slot1 0028: c4 00 00 00 ff ff ff 7f ff ff ff 7f ff ff ff 7f ........ ........
2022-11-04 15:06:05.129 src/ril_netreg.c: ril_netreg_get_signal_strength() gw: 99, lte: 30, qdbm: 0
2022-11-04 15:06:05.129 src/ril_netreg.c: ril_netreg_strength_notify() 96
2022-11-04 15:06:05.129 src/network.c: ofono_netreg_strength_notify() strength 96
2022-11-04 15:06:05.129 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength
2022-11-04 15:06:05.129 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.0::IRadioIndication currentSignalStrength
2022-11-04 15:06:05.734 src/stk.c: send_simple_response() result 0
2022-11-04 15:06:05.734 src/stk.c: stk_respond()
2022-11-04 15:06:05.734 src/ril_stk.c: ril_stk_terminal_response() rilmodem terminal response: 810301200182028281830100
2022-11-04 15:06:05.734 slot1< [00000221] STK_SEND_TERMINAL_RESPONSE
2022-11-04 15:06:05.734 slot1< 0000: 46 00 00 00 21 02 00 00 18 00 00 00 38 00 31 00 F...!... ....8.1.
2022-11-04 15:06:05.734 slot1 0008: 30 00 33 00 30 00 31 00 32 00 30 00 30 00 31 00 0.3.0.1. 2.0.0.1.
2022-11-04 15:06:05.734 slot1 0018: 38 00 32 00 30 00 32 00 38 00 32 00 38 00 31 00 8.2.0.2. 8.2.8.1.
2022-11-04 15:06:05.734 slot1 0028: 38 00 33 00 30 00 31 00 30 00 30 00 00 00 00 00 8.3.0.1. 0.0.....
2022-11-04 15:06:05.783 slot1 IRadioResponse 61 sendTerminalResponseToSim
2022-11-04 15:06:05.783 slot1> [00000221] OK
2022-11-04 15:06:05.783 slot1> 0000: 00 00 00 00 21 02 00 00 00 00 00 00 ....!... ....
2022-11-04 15:06:05.783 src/ril_stk.c: ril_stk_terminal_response_cb()
2022-11-04 15:06:05.783 src/stk.c: stk_command_cb() TERMINAL RESPONSE to a command reported no errors
2022-11-04 15:06:05.783 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien sendTerminalResponseToSimResponse ok
2022-11-04 15:06:05.788 slot1 IRadioIndication 13 stkProactiveCommand
2022-11-04 15:06:05.788 slot1> STK_PROACTIVE_COMMAND
2022-11-04 15:06:05.789 slot1> 0000: 04 00 00 00 f5 03 00 00 92 00 00 00 44 00 30 00 ........ ....D.0.
2022-11-04 15:06:05.789 slot1 0008: 34 00 37 00 38 00 31 00 30 00 33 00 30 00 31 00 4.7.8.1. 0.3.0.1.
2022-11-04 15:06:05.789 slot1 0018: 32 00 31 00 38 00 31 00 38 00 32 00 30 00 32 00 2.1.8.1. 8.2.0.2.
2022-11-04 15:06:05.789 slot1 0028: 38 00 31 00 38 00 32 00 30 00 44 00 33 00 43 00 8.1.8.2. 0.D.3.C.
2022-11-04 15:06:05.789 slot1 0038: 30 00 30 00 43 00 32 00 33 00 34 00 39 00 44 00 0.0.C.2. 3.4.9.D.
2022-11-04 15:06:05.789 slot1 0048: 35 00 45 00 30 00 36 00 38 00 39 00 43 00 42 00 5.E.0.6. 8.9.C.B.
2022-11-04 15:06:05.789 slot1 0058: 37 00 33 00 46 00 41 00 39 00 45 00 39 00 45 00 7.3.F.A. 9.E.9.E.
2022-11-04 15:06:05.789 slot1 0068: 33 00 45 00 39 00 37 00 44 00 44 00 41 00 30 00 3.E.9.7. D.D.A.0.
2022-11-04 15:06:05.789 slot1 0078: 36 00 39 00 42 00 41 00 30 00 43 00 32 00 32 00 6.9.B.A. 0.C.2.2.
2022-11-04 15:06:05.789 slot1 0088: 41 00 37 00 43 00 42 00 32 00 30 00 36 00 41 00 A.7.C.B. 2.0.6.A.
2022-11-04 15:06:05.789 slot1 0098: 37 00 39 00 34 00 45 00 30 00 46 00 42 00 42 00 7.9.4.E. 0.F.B.B.
2022-11-04 15:06:05.789 slot1 00a8: 43 00 44 00 46 00 32 00 46 00 30 00 42 00 39 00 C.D.F.2. F.0.B.9.
2022-11-04 15:06:05.789 slot1 00b8: 30 00 43 00 32 00 32 00 39 00 37 00 45 00 37 00 0.C.2.2. 9.7.E.7.
2022-11-04 15:06:05.789 slot1 00c8: 41 00 30 00 45 00 36 00 35 00 42 00 39 00 43 00 A.0.E.6. 5.B.9.C.
2022-11-04 15:06:05.790 slot1 00d8: 36 00 36 00 39 00 37 00 34 00 31 00 34 00 39 00 6.6.9.7. 4.1.4.9.
2022-11-04 15:06:05.790 slot1 00e8: 32 00 32 00 36 00 38 00 35 00 41 00 36 00 36 00 2.2.6.8. 5.A.6.6.
2022-11-04 15:06:05.790 slot1 00f8: 39 00 42 00 43 00 37 00 36 00 31 00 37 00 39 00 9.B.C.7. 6.1.7.9.
2022-11-04 15:06:05.790 slot1 0108: 31 00 39 00 30 00 34 00 37 00 44 00 43 00 42 00 1.9.0.4. 7.D.C.B.
2022-11-04 15:06:05.790 slot1 0118: 45 00 39 00 36 00 31 00 46 00 36 00 31 00 43 00 E.9.6.1. F.6.1.C.
2022-11-04 15:06:05.790 slot1 0128: 00 00 00 00 ....
2022-11-04 15:06:05.790 src/ril_stk.c: ril_stk_pcmd_notify() pcmd: D0478103012181820281820D3C00C2349D5E0689CB73FA9E9E3E97DDA069BA0C22A7CB206A794E0FBBCDF2F0B90C2297E7A0E65B9C6697414922685A669BC7617919047DCBE961F61C
2022-11-04 15:06:05.790 src/stk.c: send_simple_response() result 50
2022-11-04 15:06:05.790 src/stk.c: stk_respond()
2022-11-04 15:06:05.790 src/ril_stk.c: ril_stk_terminal_response() rilmodem terminal response: 810301218182028281830132
2022-11-04 15:06:05.790 slot1< [00000222] RESPONSE_ACK
2022-11-04 15:06:05.791 slot1< 0000: 20 03 00 00 22 02 00 00 ..."...
2022-11-04 15:06:05.791 slot1< [00000223] STK_SEND_TERMINAL_RESPONSE
2022-11-04 15:06:05.791 slot1< 0000: 46 00 00 00 23 02 00 00 18 00 00 00 38 00 31 00 F...#... ....8.1.
2022-11-04 15:06:05.791 slot1 0008: 30 00 33 00 30 00 31 00 32 00 31 00 38 00 31 00 0.3.0.1. 2.1.8.1.
2022-11-04 15:06:05.791 slot1 0018: 38 00 32 00 30 00 32 00 38 00 32 00 38 00 31 00 8.2.0.2. 8.2.8.1.
2022-11-04 15:06:05.791 slot1 0028: 38 00 33 00 30 00 31 00 33 00 32 00 00 00 00 00 8.3.0.1. 3.2.....
2022-11-04 15:06:05.791 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien stkProactiveCommand
2022-11-04 15:06:05.820 slot1 IRadioResponse 61 sendTerminalResponseToSim
2022-11-04 15:06:05.820 slot1> [00000223] OK
2022-11-04 15:06:05.820 slot1> 0000: 00 00 00 00 23 02 00 00 00 00 00 00 ....#... ....
2022-11-04 15:06:05.820 src/ril_stk.c: ril_stk_terminal_response_cb()
2022-11-04 15:06:05.820 src/stk.c: stk_command_cb() TERMINAL RESPONSE to a command reported no errors
2022-11-04 15:06:05.820 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien sendTerminalResponseToSimResponse ok
2022-11-04 15:06:05.823 slot1 IRadioIndication 14 stkEventNotify
2022-11-04 15:06:05.823 slot1> STK_EVENT_NOTIFY
2022-11-04 15:06:05.823 slot1> 0000: 04 00 00 00 f6 03 00 00 54 00 00 00 44 00 30 00 ........ T...D.0.
2022-11-04 15:06:05.823 slot1 0008: 32 00 38 00 38 00 31 00 30 00 33 00 30 00 31 00 2.8.8.1. 0.3.0.1.
2022-11-04 15:06:05.823 slot1 0018: 31 00 33 00 30 00 30 00 38 00 32 00 30 00 32 00 1.3.0.0. 8.2.0.2.
2022-11-04 15:06:05.823 slot1 0028: 38 00 31 00 38 00 33 00 30 00 36 00 30 00 37 00 8.1.8.3. 0.6.0.7.
2022-11-04 15:06:05.823 slot1 0038: 39 00 31 00 31 00 34 00 38 00 37 00 30 00 34 00 9.1.1.4. 8.7.0.4.
2022-11-04 15:06:05.823 slot1 0048: 30 00 39 00 35 00 33 00 30 00 30 00 30 00 42 00 0.9.5.3. 0.0.0.B.
2022-11-04 15:06:05.823 slot1 0058: 31 00 34 00 31 00 31 00 31 00 37 00 30 00 34 00 1.4.1.1. 1.7.0.4.
2022-11-04 15:06:05.823 slot1 0068: 38 00 31 00 39 00 31 00 37 00 30 00 37 00 46 00 8.1.9.1. 7.0.7.F.
2022-11-04 15:06:05.823 slot1 0078: 46 00 36 00 30 00 31 00 30 00 41 00 32 00 35 00 F.6.0.1. 0.A.2.5.
2022-11-04 15:06:05.823 slot1 0088: 30 00 30 00 35 00 30 00 39 00 42 00 45 00 43 00 0.0.5.0. 9.B.E.C.
2022-11-04 15:06:05.823 slot1 0098: 30 00 38 00 33 00 39 00 34 00 44 00 44 00 35 00 0.8.3.9. 4.D.D.5.
2022-11-04 15:06:05.823 slot1 00a8: 41 00 39 00 00 00 00 00 A.9.....
2022-11-04 15:06:05.824 src/ril_stk.c: ril_stk_event_notify() pcmd: D0288103011300820281830607911487040953000B141117048191707FF6010A2500509BEC08394DD5A9
2022-11-04 15:06:05.824 src/stk.c: ofono_stk_proactive_command_handled_notify() type: 19
2022-11-04 15:06:05.824 slot1< [00000224] RESPONSE_ACK
2022-11-04 15:06:05.824 slot1< 0000: 20 03 00 00 24 02 00 00 ...$...
2022-11-04 15:06:05.824 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien stkEventNotify
2022-11-04 15:06:06.184 slot1 IRadioIndication 12 stkSessionEnd
2022-11-04 15:06:06.184 slot1> STK_SESSION_END
2022-11-04 15:06:06.184 slot1> 0000: 04 00 00 00 f4 03 00 00 ........
2022-11-04 15:06:06.185 src/ril_stk.c: ril_stk_session_end_notify()
2022-11-04 15:06:06.185 slot1< [00000225] RESPONSE_ACK
2022-11-04 15:06:06.185 slot1< 0000: 20 03 00 00 25 02 00 00 ...%...
2022-11-04 15:06:06.185 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien stkSessionEnd
2022-11-04 15:06:09.608 slot1 IRadioIndication 9 currentSignalStrength
2022-11-04 15:06:09.608 slot1> SIGNAL_STRENGTH
2022-11-04 15:06:09.608 slot1> 0000: 01 00 00 00 f1 03 00 00 63 00 00 00 00 00 00 00 ........ c.......
2022-11-04 15:06:09.609 slot1 0008: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........ ........
2022-11-04 15:06:09.609 slot1 0018: ff ff ff ff 1e 00 00 00 55 00 00 00 0b 00 00 00 ........ U.......
2022-11-04 15:06:09.609 slot1 0028: ec 00 00 00 ff ff ff 7f ff ff ff 7f ff ff ff 7f ........ ........
