Mobile Duo on Sailfish
It looks like I can switch to Jolla painlessly as long as one app functions, which I need for my job: Mobile Duo. Does anyone have any experience running this identity-verification app on Sailfish?
Is it this one on the sailfish.app list? If so, it has worked in the past. Perhaps an older version can be installed on aurora?
Thanks, I hadn’t discovered that list.
Yes it works. But I do not get notifications in the background, I have to start if first.
Good that it works. As for notifications, is the “start on boot” setting turned on in the Sailfish App settings for it?
No, I mean I have to have the Duo Mobile app on screen, before I see a notification that I can approve. (No sound or message before that.)
There’s also this discussion on the Cisco Duo environment :
