Mobile data is not working (shows.‘limited connectivity’. Imho it can be related to the mnc setting for the service provider, since mobile vikings changed already 3 times the carrier network they use. And as I look into /system/etc/apns-conf.xml the mnc seems to be from the previous carrier network.
However correcting this didn’t solve the connection issue.
Apn is correctly configered in the interface, but mnc values cannot be changed there.
Were can I correct the apn settings on the device and putting the right mnc.
Mobile Vikings used the following networks since they are active in Belgium: from Base to Orange and than to Proximus.
When using the sim in an Android phone, now the Proximus settings are used and working, although on the Mobile Vikings Belgium site they report other settings, referring to their own MNC… when selecting the mobile network manually on SFOS it also showed only the id of Proximus …
Seeing how @pvs doesn’t reply I will post my access point settings from a working Android phone as I’m having the same problem (though I must admit that I’m still on 4.5.0.16).
These are configured based on a guide from Mobile Vikings:
This seems not correct as Mobile Vikings use the Proximus network when i check the Mobile Vikings website it would be MNC 01 and not 30, i will change it manual on my device and check if it works next week i have my data simcard and then i will make a pr to change it to correct the MNC code.
Here is the links where you can found the correct one:
