REPRODUCIBILITY: always
OS VERSION: 4.6
HARDWARE: sony xperia xa2
UI LANGUAGE: italian
REGRESSION: probably
When i turn mobile connection on it only gets turned on for sailfish and not for appsupport anymore
I need to go in appsupport settings, the ones you get by tapping 5 times on the android version, and enable it from there
- enable mobile data
- mobile data only turns on for sailfish and not for appsupport anymore
- need to turn on that manually
I expected the connection to activate for appsupport
I had to activate it manually
Openrepos and chum
No patchmanager nor patches
It’s actually been two days it’s doing like this and no changes has been made to the system nor software installed
