MMS works with wifi, does not work on 4G
BUILD ID = OS VERSION (Settings > About product): 4.2.0.21
HARDWARE (XA2, X10, X10 II, …): Xperia X10 II
UI LANGUAGE: English
MMS seem to only send and download on a wifi connection.
  1. Device is connected to wifi and mobile data.
  2. MMS is sent from gallery image.
  3. MMS sent with success
  4. Wifi is turned off.
  5. Same image as in step 2 is sent from gallery via MMS.
  6. MMS sent with success.
  7. Different image is sent from gallery via MMS.
  8. MMS fails.
  9. Same image as in step 2 is sent from gallery via MMS.
  10. MMS fails.
  11. Device reconnected to wifi
  12. Same image as in step 7 is sent from gallery via MMS
  13. MMS sent with success.
MMS would send with success regardless if device is connected to wifi or not.
MMS functionality seems to only work with connected to wifi, except if same image is sent a second time immediately after.
Network: Videotron 4G
MMS APN settings:
Access point name: media.videotron
Protocol: IP
Authentication: None
Proxy address: 10.208.89.17
Proxy port: 8080
MMS message centre address: http://media.videotron.com/
MMS Log (IMSI partially removed):
2021-09-30 09:01:53 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:01:53 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/__20210912_184111.jpg: image/jpeg; name=__20210912_184111.jpg
2021-09-30 09:01:53 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/__smil: application/smil; charset=utf-8; name=__smil
2021-09-30 09:01:53 [mms-dispatcher] Encode[153062] READY
2021-09-30 09:01:53 [mms-task] Encode[153062] READY → WORKING
2021-09-30 09:01:53 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (1793889 bytes)
2021-09-30 09:01:53 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:01:53 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/__20210912_184111.jpg
2021-09-30 09:01:53 [mms-attachment] Resizing (5984x3392 → 1994x1130)
2021-09-30 09:01:53 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/convert/__20210912_184111.jpg
2021-09-30 09:01:53 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471710 bytes)
2021-09-30 09:01:53 [mms-task] Encode[153062] WORKING → DONE
2021-09-30 09:01:53 [mms-dispatcher] Encode[153062] DONE
2021-09-30 09:01:53 [mms-dispatcher] Send[153062] READY
2021-09-30 09:01:53 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:01:53 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:01:53 [mms-task-http] MMS interface address 100.100.26.167
2021-09-30 09:01:53 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471710 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:01:53 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:01:53 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:01:53 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:01:53 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:01:53 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:01:53 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:02:04 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:02:04 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:02:04 [mms-ofono] Interface:
2021-09-30 09:02:04 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:02:04 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:02:04 [mms-connection-nemo] Released /ril_0
2021-09-30 09:02:09 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:02:09 [mms-dispatcher] Send[153062] READY
2021-09-30 09:02:09 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:02:09 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:02:09 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:02:09 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:02:09 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:02:09 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:02:09 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:02:09 [mms-ofono] Settings.Method: static
2021-09-30 09:02:09 [mms-ofono] Settings.Address: 100.100.26.167
2021-09-30 09:02:09 [mms-ofono] Settings.Netmask: 255.255.255.240
2021-09-30 09:02:09 [mms-ofono] Settings.Gateway: 100.100.26.168
2021-09-30 09:02:09 [mms-ofono] Settings.DomainNameServers: 10.208.36.194 10.208.37.45
2021-09-30 09:02:09 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:02:09 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:02:09 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:02:09 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:02:09 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:02:09 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:02:09 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:02:09 [mms-task-http] MMS interface address 100.100.26.167
2021-09-30 09:02:09 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471710 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:02:09 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:02:09 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:02:09 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:02:09 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:02:09 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:02:09 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:02:09 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:02:20 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:02:20 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:02:20 [mms-ofono] Interface:
2021-09-30 09:02:20 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:02:20 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:02:20 [mms-connection-nemo] Released /ril_0
2021-09-30 09:02:23 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:02:25 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:02:25 [mms-dispatcher] Send[153062] READY
2021-09-30 09:02:25 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:02:25 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:02:25 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:02:25 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:02:25 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:02:25 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:02:25 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:02:25 [mms-ofono] Settings.Method: static
2021-09-30 09:02:25 [mms-ofono] Settings.Address: 100.100.26.167
2021-09-30 09:02:25 [mms-ofono] Settings.Netmask: 255.255.255.240
2021-09-30 09:02:25 [mms-ofono] Settings.Gateway: 100.100.26.168
2021-09-30 09:02:25 [mms-ofono] Settings.DomainNameServers: 10.208.36.194 10.208.37.45
2021-09-30 09:02:25 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:02:25 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:02:25 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:02:25 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:02:25 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:02:25 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:02:25 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:02:25 [mms-task-http] MMS interface address 100.100.26.167
2021-09-30 09:02:25 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471710 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:02:25 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:02:25 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:02:25 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:02:25 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:02:25 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:02:25 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:02:25 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:02:32 [mms-engine] mms_engine_handle_cancel() 153062
2021-09-30 09:02:32 [mms-task] mms_task_cancel() Send[153062]
2021-09-30 09:02:32 [mms-task] Send[153062] SLEEP → DONE
2021-09-30 09:02:32 [mms-dispatcher] Send[153062] DONE
2021-09-30 09:02:36 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:02:36 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:02:36 [mms-ofono] Interface:
2021-09-30 09:02:36 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:02:36 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:02:36 [mms-connection-nemo] Released /ril_0
2021-09-30 09:02:36 [mms-engine] All done
2021-09-30 09:03:03 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:03:16 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:03:16 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/___20210912_184111.jpg: image/jpeg; name=___20210912_184111.jpg
2021-09-30 09:03:16 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/___smil: application/smil; charset=utf-8; name=___smil
2021-09-30 09:03:16 [mms-dispatcher] Encode[153062] READY
2021-09-30 09:03:16 [mms-task] Encode[153062] READY → WORKING
2021-09-30 09:03:16 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (1793895 bytes)
2021-09-30 09:03:16 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:03:16 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/___20210912_184111.jpg
2021-09-30 09:03:16 [mms-attachment] Resizing (5984x3392 → 1994x1130)
2021-09-30 09:03:16 [dbusaccess] Parsing /proc/6256/status
2021-09-30 09:03:17 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/convert/___20210912_184111.jpg
2021-09-30 09:03:17 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes)
2021-09-30 09:03:17 [mms-task] Encode[153062] WORKING → DONE
2021-09-30 09:03:17 [mms-dispatcher] Encode[153062] DONE
2021-09-30 09:03:17 [mms-dispatcher] Send[153062] READY
2021-09-30 09:03:17 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:03:17 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:03:17 [mms-ofono] ril_0: not attached
2021-09-30 09:03:17 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:03:17 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:03:17 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:03:17 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:03:17 [mms-ofono] ERROR: GDBus.Error:org.ofono.Error.Failed: Operation failed
2021-09-30 09:03:17 [mms-ofono] Giving up on /ril_0/context2
2021-09-30 09:03:17 [mms-dispatcher] 302500XXXXXXXXX FAILED
2021-09-30 09:03:17 [mms-task] Send[153062] NEED_CONNECTION → SLEEP
2021-09-30 09:03:17 [mms-connection-nemo] Connection 302500XXXXXXXXX cancelled
2021-09-30 09:03:17 [mms-connection-nemo] Released /ril_0
2021-09-30 09:03:33 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:03:33 [mms-dispatcher] Send[153062] READY
2021-09-30 09:03:33 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:03:33 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:03:33 [mms-ofono] ril_0: not attached
2021-09-30 09:03:33 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:03:33 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:03:33 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:03:33 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:03:35 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:03:35 [mms-ofono] Settings.Method: static
2021-09-30 09:03:35 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:03:35 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:03:35 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:03:35 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:03:35 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:03:35 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:03:35 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:03:35 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:03:35 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:03:35 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:03:35 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:03:35 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:03:35 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:03:35 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:03:35 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:03:35 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:03:35 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:03:36 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:03:36 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:03:36 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:03:46 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:03:46 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:03:46 [mms-ofono] Interface:
2021-09-30 09:03:46 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:03:46 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:03:46 [mms-connection-nemo] Released /ril_0
2021-09-30 09:03:47 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:03:51 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:03:51 [mms-dispatcher] Send[153062] READY
2021-09-30 09:03:51 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:03:51 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:03:51 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:03:51 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:03:51 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:03:51 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:03:51 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:03:51 [mms-ofono] Settings.Method: static
2021-09-30 09:03:51 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:03:51 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:03:51 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:03:51 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:03:51 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:03:51 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:03:51 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:03:51 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:03:51 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:03:51 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:03:51 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:03:51 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:03:51 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:03:51 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:03:51 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:03:51 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:03:51 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:03:51 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:03:51 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:03:51 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:04:02 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:04:02 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:04:02 [mms-ofono] Interface:
2021-09-30 09:04:02 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:04:02 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:04:02 [mms-connection-nemo] Released /ril_0
2021-09-30 09:04:07 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:04:07 [mms-dispatcher] Send[153062] READY
2021-09-30 09:04:07 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:04:07 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:04:07 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:04:07 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:04:07 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:04:07 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:04:07 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:04:07 [mms-ofono] Settings.Method: static
2021-09-30 09:04:07 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:04:07 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:04:07 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:04:07 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:04:07 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:04:07 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:04:07 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:04:07 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:04:07 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:04:07 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:04:07 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:04:07 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:04:07 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:04:07 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:04:07 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:04:07 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:04:07 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:04:07 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:04:07 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:04:07 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:04:18 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:04:18 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:04:18 [mms-ofono] Interface:
2021-09-30 09:04:18 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:04:18 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:04:18 [mms-connection-nemo] Released /ril_0
2021-09-30 09:04:23 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:04:23 [mms-dispatcher] Send[153062] READY
2021-09-30 09:04:23 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:04:23 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:04:23 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:04:23 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:04:23 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:04:23 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:04:23 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:04:23 [mms-ofono] Settings.Method: static
2021-09-30 09:04:23 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:04:23 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:04:23 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:04:23 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:04:23 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:04:23 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:04:23 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:04:23 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:04:23 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:04:23 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:04:23 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:04:23 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:04:23 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:04:23 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:04:23 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:04:23 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:04:23 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:04:23 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:04:23 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:04:23 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:04:34 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:04:34 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:04:34 [mms-ofono] Interface:
2021-09-30 09:04:34 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:04:34 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:04:34 [mms-connection-nemo] Released /ril_0
2021-09-30 09:04:39 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:04:39 [mms-dispatcher] Send[153062] READY
2021-09-30 09:04:39 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:04:39 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:04:39 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:04:39 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:04:39 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:04:39 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:04:39 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:04:39 [mms-ofono] Settings.Method: static
2021-09-30 09:04:39 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:04:39 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:04:39 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:04:39 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:04:39 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:04:39 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:04:39 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:04:39 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:04:39 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:04:39 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:04:39 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:04:39 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:04:39 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:04:39 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:04:39 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:04:39 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:04:39 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:04:39 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:04:39 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:04:39 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:04:50 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:04:50 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:04:50 [mms-ofono] Interface:
2021-09-30 09:04:50 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:04:50 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:04:50 [mms-connection-nemo] Released /ril_0
2021-09-30 09:04:55 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:04:55 [mms-dispatcher] Send[153062] READY
2021-09-30 09:04:55 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:04:55 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:04:55 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:04:55 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:04:55 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:04:55 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:04:55 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:04:55 [mms-ofono] Settings.Method: static
2021-09-30 09:04:55 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:04:55 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:04:55 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:04:55 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:04:55 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:04:55 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:04:55 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:04:55 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:04:55 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:04:55 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:04:55 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:04:55 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:04:55 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:04:55 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:04:55 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:04:55 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:04:55 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:04:55 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:04:55 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:04:55 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:05:06 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:05:06 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:05:06 [mms-ofono] Interface:
2021-09-30 09:05:06 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:05:06 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:05:06 [mms-connection-nemo] Released /ril_0
2021-09-30 09:05:11 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:05:11 [mms-dispatcher] Send[153062] READY
2021-09-30 09:05:11 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:05:11 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:05:11 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:05:11 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:05:11 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:05:11 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:05:11 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:05:11 [mms-ofono] Settings.Method: static
2021-09-30 09:05:11 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:05:11 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:05:11 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:05:11 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:05:11 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:05:11 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:05:11 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:05:11 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:05:11 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:05:11 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:05:11 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:05:11 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:05:11 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:05:11 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:05:11 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:05:11 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:05:11 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:05:11 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:05:11 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:05:11 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:05:22 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:05:22 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:05:22 [mms-ofono] Interface:
2021-09-30 09:05:22 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:05:22 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:05:22 [mms-connection-nemo] Released /ril_0
2021-09-30 09:05:27 [mms-task] Send[153062] SLEEP → READY
2021-09-30 09:05:27 [mms-dispatcher] Send[153062] READY
2021-09-30 09:05:27 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:05:27 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:05:27 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:05:27 [mms-connection-nemo] MessageCenter: http://media.videotron.com
2021-09-30 09:05:27 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:05:27 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:05:27 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:05:27 [mms-ofono] Settings.Method: static
2021-09-30 09:05:27 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:05:27 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:05:27 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:05:27 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:05:27 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:05:27 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:05:27 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:05:27 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:05:27 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:05:27 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:05:27 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:05:27 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:05:27 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471716 bytes) → http://media.videotron.com → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:05:27 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:05:27 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:05:27 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:05:27 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:05:27 [mms-task-http] HTTP status 2 (Cannot resolve hostname)
2021-09-30 09:05:27 [mms-task] Send[153062] TRANSMITTING → SLEEP
2021-09-30 09:05:27 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:05:36 [mms-engine] mms_engine_handle_cancel() 153062
2021-09-30 09:05:36 [mms-task] mms_task_cancel() Send[153062]
2021-09-30 09:05:36 [mms-task] Send[153062] SLEEP → DONE
2021-09-30 09:05:36 [mms-dispatcher] Send[153062] DONE
2021-09-30 09:05:38 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:05:38 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:05:38 [mms-ofono] Interface:
2021-09-30 09:05:38 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:05:38 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:05:38 [mms-connection-nemo] Released /ril_0
2021-09-30 09:05:38 [mms-engine] All done
2021-09-30 09:06:07 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:06:30 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:06:30 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/____20210912_184111.jpg: image/jpeg; name=____20210912_184111.jpg
2021-09-30 09:06:30 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/____smil: application/smil; charset=utf-8; name=____smil
2021-09-30 09:06:30 [mms-dispatcher] Encode[153062] READY
2021-09-30 09:06:30 [mms-task] Encode[153062] READY → WORKING
2021-09-30 09:06:30 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (1793901 bytes)
2021-09-30 09:06:30 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:06:30 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/____20210912_184111.jpg
2021-09-30 09:06:30 [mms-attachment] Resizing (5984x3392 → 1994x1130)
2021-09-30 09:06:30 [dbusaccess] Parsing /proc/6256/status
2021-09-30 09:06:30 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/encode/convert/____20210912_184111.jpg
2021-09-30 09:06:30 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471722 bytes)
2021-09-30 09:06:30 [mms-task] Encode[153062] WORKING → DONE
2021-09-30 09:06:30 [mms-dispatcher] Encode[153062] DONE
2021-09-30 09:06:30 [mms-dispatcher] Send[153062] READY
2021-09-30 09:06:30 [mms-task] Send[153062] READY → NEED_CONNECTION
2021-09-30 09:06:30 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:06:30 [mms-ofono] ril_0: not attached
2021-09-30 09:06:30 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:06:30 [mms-connection-nemo] MessageProxy: 10.208.89.17:8080
2021-09-30 09:06:30 [mms-connection-nemo] MessageCenter: http://media.videotron.com/
2021-09-30 09:06:30 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:06:30 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:06:31 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:06:31 [mms-ofono] Settings.Method: static
2021-09-30 09:06:31 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:06:31 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:06:31 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:06:31 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:06:31 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:06:31 [mms-connection-nemo] Interface: rmnet_data1
2021-09-30 09:06:31 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:06:31 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:06:31 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:06:31 [mms-dispatcher] Send[153062] NEED_CONNECTION
2021-09-30 09:06:31 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:06:31 [mms-task-http] MMS proxy 10.208.89.17:8080
2021-09-30 09:06:31 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.req (471722 bytes) → http://media.videotron.com/ → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153062/m-send.conf
2021-09-30 09:06:31 [mms-transfer-list] Transfer /msg/153062/Send started
2021-09-30 09:06:31 [mms-task] Send[153062] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:06:31 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:06:31 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:06:32 [mms-task-http] HTTP status 200 [application/vnd.wap.mms-message] 40 byte(s)
2021-09-30 09:06:32 [mms-task] Send[153062] TRANSMITTING → DONE
2021-09-30 09:06:32 [mms-transfer-list] Transfer /msg/153062/Send finished
2021-09-30 09:06:32 [mms-task-send] Message ID 8fHx5P00MB3x8fHx8fHx8fHx
2021-09-30 09:06:32 [mms-dispatcher] Send[153062] DONE
2021-09-30 09:06:42 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:06:42 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:06:42 [mms-ofono] Interface:
2021-09-30 09:06:42 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:06:42 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:06:42 [mms-connection-nemo] Released /ril_0
2021-09-30 09:06:42 [mms-engine] All done
2021-09-30 09:07:00 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:07:01 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:07:51 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:07:51 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/20210320_162732.jpg: image/jpeg; name=20210320_162732.jpg
2021-09-30 09:07:51 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/2.txt: no conversion required
2021-09-30 09:07:51 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/2.txt: text/plain; charset=utf-8; name=2.txt
2021-09-30 09:07:51 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/smil: application/smil; charset=utf-8; name=smil
2021-09-30 09:07:51 [mms-dispatcher] Encode[153066] READY
2021-09-30 09:07:51 [mms-task] Encode[153066] READY → WORKING
2021-09-30 09:07:51 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/m-send.req (3696844 bytes)
2021-09-30 09:07:51 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:07:51 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/20210320_162732.jpg
2021-09-30 09:07:51 [mms-attachment] Decoder-assisted resize (4000x3000 → 2000x1500)
2021-09-30 09:07:51 [dbusaccess] Parsing /proc/6256/status
2021-09-30 09:07:51 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/encode/convert/20210320_162732.jpg
2021-09-30 09:07:51 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/m-send.req (933982 bytes)
2021-09-30 09:07:51 [mms-task] Encode[153066] WORKING → DONE
2021-09-30 09:07:51 [mms-dispatcher] Encode[153066] DONE
2021-09-30 09:07:51 [mms-dispatcher] Send[153066] READY
2021-09-30 09:07:51 [mms-task] Send[153066] READY → NEED_CONNECTION
2021-09-30 09:07:51 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:07:51 [mms-ofono] ril_0: not attached
2021-09-30 09:07:51 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:07:51 [mms-connection-nemo] MessageProxy: 10.208.89.17:8080
2021-09-30 09:07:51 [mms-connection-nemo] MessageCenter: http://media.videotron.com/
2021-09-30 09:07:51 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:07:51 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:07:52 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:07:52 [mms-ofono] Settings.Method: static
2021-09-30 09:07:52 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:07:52 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:07:52 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:07:52 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:07:52 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:07:52 [mms-connection-nemo] Interface: rmnet_data0
2021-09-30 09:07:52 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:07:52 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:07:52 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:07:52 [mms-dispatcher] Send[153066] NEED_CONNECTION
2021-09-30 09:07:52 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:07:52 [mms-task-http] MMS proxy 10.208.89.17:8080
2021-09-30 09:07:52 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/m-send.req (933982 bytes) → http://media.videotron.com/ → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153066/m-send.conf
2021-09-30 09:07:52 [mms-transfer-list] Transfer /msg/153066/Send started
2021-09-30 09:07:52 [mms-task] Send[153066] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:07:52 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:07:52 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:07:53 [mms-task-http] HTTP status 200 [application/vnd.wap.mms-message] 40 byte(s)
2021-09-30 09:07:53 [mms-task] Send[153066] TRANSMITTING → DONE
2021-09-30 09:07:53 [mms-transfer-list] Transfer /msg/153066/Send finished
2021-09-30 09:07:53 [mms-task-send] Message ID 5OTk8eghJh7k5OTk5OTk5OTk
2021-09-30 09:07:53 [mms-dispatcher] Send[153066] DONE
2021-09-30 09:08:03 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:08:03 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:08:03 [mms-ofono] Interface:
2021-09-30 09:08:03 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:08:03 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:08:03 [mms-connection-nemo] Released /ril_0
2021-09-30 09:08:03 [mms-engine] All done
2021-09-30 09:08:21 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:08:23 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:24:39 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:24:39 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/20210320_162732.jpg: image/jpeg; name=20210320_162732.jpg
2021-09-30 09:24:39 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/2.txt: no conversion required
2021-09-30 09:24:39 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/2.txt: text/plain; charset=utf-8; name=2.txt
2021-09-30 09:24:39 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/smil: application/smil; charset=utf-8; name=smil
2021-09-30 09:24:39 [mms-dispatcher] Encode[153067] READY
2021-09-30 09:24:39 [mms-task] Encode[153067] READY → WORKING
2021-09-30 09:24:39 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/m-send.req (3696844 bytes)
2021-09-30 09:24:39 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:24:39 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/20210320_162732.jpg
2021-09-30 09:24:39 [mms-attachment] Decoder-assisted resize (4000x3000 → 2000x1500)
2021-09-30 09:24:39 [dbusaccess] Parsing /proc/6256/status
2021-09-30 09:24:39 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/encode/convert/20210320_162732.jpg
2021-09-30 09:24:39 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/m-send.req (933982 bytes)
2021-09-30 09:24:39 [mms-task] Encode[153067] WORKING → DONE
2021-09-30 09:24:39 [mms-dispatcher] Encode[153067] DONE
2021-09-30 09:24:39 [mms-dispatcher] Send[153067] READY
2021-09-30 09:24:39 [mms-task] Send[153067] READY → NEED_CONNECTION
2021-09-30 09:24:39 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:24:39 [mms-ofono] ril_0: not attached
2021-09-30 09:24:39 [mms-ofono] Context /ril_0/context1 is active
2021-09-30 09:24:39 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:24:39 [mms-ofono] Settings.Method: static
2021-09-30 09:24:39 [mms-ofono] Settings.Address: 100.91.210.112
2021-09-30 09:24:39 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:24:39 [mms-ofono] Settings.Gateway: 100.91.210.113
2021-09-30 09:24:39 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:24:39 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:24:39 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:24:39 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:24:39 [mms-connection-nemo] MessageProxy: 10.208.89.17:8080
2021-09-30 09:24:39 [mms-connection-nemo] MessageCenter: http://media.videotron.com/
2021-09-30 09:24:39 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:24:39 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:24:40 [mms-ofono] Settings.Interface: rmnet_data2
2021-09-30 09:24:40 [mms-ofono] Settings.Method: static
2021-09-30 09:24:40 [mms-ofono] Settings.Address: 100.93.11.144
2021-09-30 09:24:40 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:24:40 [mms-ofono] Settings.Gateway: 100.93.11.145
2021-09-30 09:24:40 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:24:40 [mms-ofono] Interface: rmnet_data2
2021-09-30 09:24:40 [mms-connection-nemo] Interface: rmnet_data2
2021-09-30 09:24:40 [mms-ofono] Context /ril_0/context2 is active
2021-09-30 09:24:40 [mms-connection-nemo] Connection 302500XXXXXXXXX opened
2021-09-30 09:24:40 [mms-dispatcher] 302500XXXXXXXXX OPEN
2021-09-30 09:24:40 [mms-dispatcher] Send[153067] NEED_CONNECTION
2021-09-30 09:24:40 [mms-task-http] MMS interface address 100.93.11.144
2021-09-30 09:24:40 [mms-task-http] MMS proxy 10.208.89.17:8080
2021-09-30 09:24:40 [mms-task-http] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/m-send.req (933982 bytes) → http://media.videotron.com/ → /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153067/m-send.conf
2021-09-30 09:24:40 [mms-transfer-list] Transfer /msg/153067/Send started
2021-09-30 09:24:40 [mms-task] Send[153067] NEED_CONNECTION → TRANSMITTING
2021-09-30 09:24:40 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-30 09:24:40 [mms-transfer-list] Update flags => 0x11
2021-09-30 09:24:41 [mms-task-http] HTTP status 200 [application/vnd.wap.mms-message] 40 byte(s)
2021-09-30 09:24:41 [mms-task] Send[153067] TRANSMITTING → DONE
2021-09-30 09:24:41 [mms-transfer-list] Transfer /msg/153067/Send finished
2021-09-30 09:24:41 [mms-task-send] Message ID EhISBB7XbqMSEhISEhISEhIS
2021-09-30 09:24:41 [mms-dispatcher] Send[153067] DONE
2021-09-30 09:24:51 [mms-connection-nemo] Deactivate /ril_0/context2
2021-09-30 09:24:51 [mms-ofono] Deactivating /ril_0/context2
2021-09-30 09:24:51 [mms-ofono] Interface:
2021-09-30 09:24:51 [mms-ofono] Context /ril_0/context2 is not active
2021-09-30 09:24:51 [mms-dispatcher] 302500XXXXXXXXX CLOSED
2021-09-30 09:24:51 [mms-connection-nemo] Released /ril_0
2021-09-30 09:24:51 [mms-engine] All done
2021-09-30 09:25:09 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:25:11 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:25:40 [dbusaccess] Parsing /proc/6245/status
2021-09-30 09:25:40 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/20210320_160457.jpg: image/jpeg; name=20210320_160457.jpg
2021-09-30 09:25:40 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/2.txt: no conversion required
2021-09-30 09:25:40 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/2.txt: text/plain; charset=utf-8; name=2.txt
2021-09-30 09:25:40 [mms-attachment] /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/smil: application/smil; charset=utf-8; name=smil
2021-09-30 09:25:40 [mms-dispatcher] Encode[153068] READY
2021-09-30 09:25:40 [mms-task] Encode[153068] READY → WORKING
2021-09-30 09:25:40 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/m-send.req (5548473 bytes)
2021-09-30 09:25:40 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:25:40 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/20210320_160457.jpg
2021-09-30 09:25:40 [mms-attachment] Decoder-assisted resize (4000x3000 → 2000x1500)
2021-09-30 09:25:41 [dbusaccess] Parsing /proc/6256/status
2021-09-30 09:25:41 [mms-attachment] Resized /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/convert/20210320_160457.jpg
2021-09-30 09:25:41 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/m-send.req (1632000 bytes)
2021-09-30 09:25:41 [mms-task-encode] Message is too big, need to resize
2021-09-30 09:25:41 [mms-task-encode] Resizing /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/encode/20210320_160457.jpg
2021-09-30 09:25:41 [mms-attachment] Resizing (4000x3000 → 1333x1000)
2021-09-30 09:25:41 [mms-task-encode] Created /tmp/mms_UDae4I/mms2021-09-29T223241/msg/153068/m-send.req (746438 bytes)
2021-09-30 09:25:41 [mms-task] Encode[153068] WORKING → DONE
2021-09-30 09:25:41 [mms-dispatcher] Encode[153068] DONE
2021-09-30 09:25:41 [mms-dispatcher] Send[153068] READY
2021-09-30 09:25:41 [mms-task] Send[153068] READY → NEED_CONNECTION
2021-09-30 09:25:41 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:25:41 [mms-ofono] ril_0: not attached
2021-09-30 09:25:41 [mms-ofono] Context /ril_0/context1 is active
2021-09-30 09:25:41 [mms-ofono] Settings.Interface: rmnet_data1
2021-09-30 09:25:41 [mms-ofono] Settings.Method: static
2021-09-30 09:25:41 [mms-ofono] Settings.Address: 100.91.210.112
2021-09-30 09:25:41 [mms-ofono] Settings.Netmask: 255.255.255.224
2021-09-30 09:25:41 [mms-ofono] Settings.Gateway: 100.91.210.113
2021-09-30 09:25:41 [mms-ofono] Settings.DomainNameServers: 10.208.36.186 10.208.37.47
2021-09-30 09:25:41 [mms-ofono] Interface: rmnet_data1
2021-09-30 09:25:41 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2021-09-30 09:25:41 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:25:41 [mms-connection-nemo] MessageProxy: 10.208.89.17:8080
2021-09-30 09:25:41 [mms-connection-nemo] MessageCenter: http://media.videotron.com/
2021-09-30 09:25:41 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:25:41 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:25:41 [mms-ofono] ERROR: GDBus.Error:org.ofono.Error.Failed: Operation failed
2021-09-30 09:25:41 [mms-ofono] Giving up on /ril_0/context2
2021-09-30 09:25:41 [mms-dispatcher] 302500XXXXXXXXX FAILED
2021-09-30 09:25:41 [mms-task] Send[153068] NEED_CONNECTION → SLEEP
2021-09-30 09:25:41 [mms-connection-nemo] Connection 302500XXXXXXXXX cancelled
2021-09-30 09:25:41 [mms-connection-nemo] Released /ril_0
2021-09-30 09:25:57 [mms-task] Send[153068] SLEEP → READY
2021-09-30 09:25:57 [mms-dispatcher] Send[153068] READY
2021-09-30 09:25:57 [mms-task] Send[153068] READY → NEED_CONNECTION
2021-09-30 09:25:57 [mms-connection-nemo] MMS modem path /ril_0
2021-09-30 09:25:57 [mms-ofono] ril_0: not attached
2021-09-30 09:25:57 [mms-ofono] Context /ril_0/context1 is active
2021-09-30 09:25:57 [mms-ofono] Settings.Interface: rmnet_data0
2021-09-30 09:25:57 [mms-ofono] Settings.Method: static
2021-09-30 09:25:57 [mms-ofono] Settings.Address: 100.87.138.124
2021-09-30 09:25:57 [mms-ofono] Settings.Netmask: 255.255.255.248
2021-09-30 09:25:57 [mms-ofono] Settings.Gateway: 100.87.138.125
2021-09-30 09:25:57 [mms-ofono] Settings.DomainNameServers: 10.208.36.194 10.208.37.45
2021-09-30 09:25:57 [mms-ofono] Interface: rmnet_data0
2021-09-30 09:25:57 [mms-ofono] IPv6.Settings.Interface: rmnet_data0
2021-09-30 09:25:57 [mms-connection-nemo] MMS context /ril_0/context2
2021-09-30 09:25:57 [mms-connection-nemo] MessageProxy: 10.208.89.17:8080
2021-09-30 09:25:57 [mms-connection-nemo] MessageCenter: http://media.videotron.com/
2021-09-30 09:25:57 [mms-connection-nemo] Activate /ril_0/context2
2021-09-30 09:25:57 [mms-ofono] Activating /ril_0/context2
2021-09-30 09:25:57 [mms-ofono] ERROR: GDBus.Error:org.ofono.Error.Failed: Operation failed
2021-09-30 09:25:57 [mms-ofono] Giving up on /ril_0/context2
2021-09-30 09:25:57 [mms-dispatcher] 302500XXXXXXXXX FAILED
2021-09-30 09:25:57 [mms-task] Send[153068] NEED_CONNECTION → SLEEP
2021-09-30 09:25:57 [mms-connection-nemo] Connection 302500XXXXXXXXX cancelled
2021-09-30 09:25:57 [mms-connection-nemo] Released /ril_0
2021-09-30 09:26:11 [dbusaccess] Name ‘:1.121’ timed out
2021-09-30 09:26:11 [dbusaccess] Name ‘:1.124’ timed out
2021-09-30 09:26:13 [mms-task] Send[153068] SLEEP → READY
2021-09-30 09:26:13 [mms-dispatcher] Send[153068] READY
Does MMS actually work across wifi? I kind of thought it was like text messages (SMS) in that these always go across the mobile network?
I had MMS problems on UK EE - they couldn’t be delivered or sent. The fix, for me, was easy - the jolla supplied default APN and proxy settings for EE were wrong. Simply by googling the correct settings and using those MMS then worked fine for both sending and receiving.
The message goes through the mobile network, but extra the data goes over a generic data connection, where at least some operators allow accessing it from any connection.
This sounds like MMS problem simillar to the problem which users from USA have.
This carrier is from Canada so maybe it’s the same problem.
From Videotron page:
APN for a 4G SIM card and device: media.videotron
APN for an LTE SIM card and device: media.ng
MMSC : http://media.videotron.com
MCC : 302
MNC : 500
APN Type: default,mms,supl
Leave all other fields empty.
Jolla config for Videotrom:
apn value=“media.videotron”
> usage type=“mms”/
> name Videotron MMS
> mms chttp://media.videotron.com/
> mmsproxy 10.208.89.17:8080
So Jolla config != config from carrier page.
@oenone have you tried config for “APN for an LTE SIM card and device: media.ng”
Recognized for me in Sweden also. I had the first impression that it did work better on 4.2.0.21 on my 10 II but after the first received MMS I have to enable WiFi or HotSpot to be able to send or receive MMS. I did initially had to toggel the Dual / IP setting to get it to work on 4G but as of no I don’t think it matters.
I am not sure if Videotron shovels MMS across wifi when possible, but it would not surprise me if they do, considering their incredibly generous wifi-calling (not available on Sailfish OS of course :slightly_smiling_face:) which basically treats any wifi connection as the home network, allowing for both calls/SMS/MMS local to the country the internet connection is in and back to Canada.
Meaning, as an example, you go to IKEA in Brussels, connect to the wifi, and you can both call/SMS/MMS across Belgium and across Canada without any roaming charges.
So maybe they do pass what they can across wifi if possible? Is there a way to tell? Do I need to do some ofono logging?
Changing to media.ng results in exactly the same behaviour: When connected to data and wifi MMS will send, when only connected to data MMS fails to send.
Also deleting the proxy value results in MMS not working completely, so Jolla’s configuration is better than the one that Videotron provides.
Could this be a dual stack ipV4 vs ipV6 issue? or rather lack thereof? Often mobile phones are on pure ipV6 stacks these days with some flaky gateways to ipV4 land?
I’m just tossing an idea in.
I just tested MMS with my XA2, Verla, Vodafone Germany and an iPhone SE on German Telekom in both directions.
Works.
So there is no generic problem with MMS.
Wrong Gateway, maybe?
Not obviously; and it would be pretty bad network config that breaks itself.
I’d suspect DNS over this, but without supporting evidence… who knows.
I was thinking of the case where they give out ipV6 addresses but mms is still ipV4. But the last time I saw that is some years ago (Vodafone, I think). On 02 here in Germany, it’s all ipvV4. And the automagic settings for MMS are all ipV4 addresses. no names. That’s not how I’d do it :slight_smile:
My IP on Vodafone (Germany) is 109.40.240.61, IPv4 (and I will be @ Pfefferberg ;-)), my Proxy is 139.7.29.17:80 and MMS Gate is at 139.7.24.1/servlets/mms. So no IPv6 gets in the way.
As people seems to be able to get it to work playing with the IP / Dual settings I gave it a try. After that I am not able to send or receive MMS at all. I have tried all combinations of IP / IP6 / Dual for both Data and MMS settings, but to no avail. My original setting where Dual for both and then I where able to send and receive MMS if I enabled WiFi or my HotSpot. But now fiddling with the WiFi stuff don’t help at all :frowning:
Verla on my Xperia 10 II
Ah, interesting. On residential cable (x kabel deutschland) Vodafone is doing single stack ipV6 by default. Which is why I asked for ipV4, which I get for free, but no dualstack. pita! Strange. I set up dual stack servers all the time. It’s not that difficult!!! And dns? hmmm. Who knows.
I’m also coming to Pfefferberg. It’s just down the street from my office :wink:
Vodafone Cable here sets me to
IPv4 77.20.107.4
IPv6 2a02:8109:8000:51:8ff:857a:eebe:9df7
(I had to ask Kabel Deutschland for the IPv4 address, too.)
The IP## I sent before where on Vodafone mobile.
DUAL stack. no way. I asked them and must have got an easily annoyed admin. Man.I’m trying to test but have to get some contacts on the phone :wink:
Edit: Just tested from 4.2. Default settings for MMS (ipV4) with both sim/wifi works. shut down wifi. MMS doesn’t work (although this might be because one needs a reboot?). turn wifi on, reboot MMS work.
I’ll see if I can append later. I’m actually using 3.4 in practice so I have to switch out hardware.
I actually tested MMS by switching off WiFi and switching on mobile network. No reboot. Standard settings for Vodafone prepaid Germany.
Strange. I would have thought it must work with IP and Loop. But It currently isn’t That’s with O2 as the 4G provider. So I seem to have the same symptoms with 4.2 and 4G. Works fine on
EDIT. 3.4
with the same sim
and provider
and settings
behaves differently but also fails if I’m only on 4G. The difference is, start sending an MMS with 4G only, watch the wheel spin. Turn on wifi, bling, the MMS goes through. On 4.2, turning on wifi doesn’t result in the MMS going through. I have to reboot.
Hmm, so from this I understand that this is not a unique bug to Videotron. I wonder if there is additional information that I could provide to help fix this bug, should it be found to be common with others also failing to have usable MMS functionality without wifi? Ofono logs? Maybe get in touch with Jolla directly?
