Mms takes many attempts to download
REPRODUCIBILITY: always
OS VERSION: 4.6.0.15-xqbt52-1.0.1.14
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION: no
MMS downloads work, but take many many attempts. When I receive an MMS, it invariably fails to download. I start the download again, then try the following things in combination, waiting various amounts of time:
  • disable wifi (or sometimes, in despair, enabling wifi)
  • restart mms-engine
  • restart ofono
  • change MMS IPv4 => IPv6 => dual
  • change mobile data IPv4 => IPv6 => dual
It generally takes about 5 full minutes to work. Sometimes, the MMS will download the instant a stop ofono, indicating that it had already downloaded correctly and was just hanging on ack or something. More often, restarting mms-engine will cause it to work fairly normally after about 5 seconds.
This happens regardless of MMS size. Text-only MMS messages have the same symptoms as 1MiB MMS messages.
Receive an MMS
It seems to be reliable to do just the following:
  • hit cancel download
  • disable wifi + set mobile=IPv4 + set mms=Dual + restart ofono
  • hit download mms + restart mms-engine + restart ofono
  • then, in a loop: restart mms-engine + download mms, maybe about 20 times.
MMS downloads on the first attempt, or better yet, automatically, without failing.
MMS takes 20+ attempts to download.
No relevant modifications.
Attached is one attempt, just now, taking the path in steps-to-reproduce. It downloaded correctly in the end. I don’t know enough about networking, especially IPv6/CLAT/etc to tell if there is anything relevant in it.
Logs have only the following replacements: IMEI=333666777888999, sender=15554442222, recipient=15554443333. If anyone notices that there is any personal info in there I should not be sharing publicly, please let me know.
logs in xz’d tar file encoded in base64 with wrapper script to extract:
#!/bin/sh
B64="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echo "$B64" | base64 -d > 20241022_104119_mms-engine-logs.tar.xz
xz -d 20241022_104119_mms-engine-logs.tar.xz
tar -xf 20241022_104119_mms-engine-logs.tar
Oh, nice. I’ll have to steal that!
For me mms worked only on 3g, maybe turning ipv4<->6 has a side effect of dropping you to 3g and it happens to download in this window? Worth a try as a reliable workaround if it works
thanks, but 3G does not exist in my country
Probably carrier dependent, what about 2g? The only thing I know for sure is no matter how many attempts on 4g all resulted in failure for me for whatever reason, worth a try
yea, a good idea. 2G is very limited here, but was worth trying.
i just tried for a solid 30 minutes on 2G-only, and could not get it to download. ofono icon said 2.5G. probably the connection is too spotty.
every successful MMS download so far has been definitely on lte (10 III nr bands are not available here) with ofono icon 4G
ok, i confirmed the problem is DEFINITELY with ‘Ack’. i modified mms-engine like this:
wolke:~/Code/mms-engine$ git diff
diff --git a/mms-lib/src/mms_task_ack.c b/mms-lib/src/mms_task_ack.c
index b9ed5d6..a49abb4 100644
--- a/mms-lib/src/mms_task_ack.c
+++ b/mms-lib/src/mms_task_ack.c
@@ -53,6 +53,7 @@ mms_task_ack_new(
     MMSTransferList* transfers,
     const char* tx_id)
+    return NULL;
     MMSTask* task = NULL;
     const char* file = mms_task_ack_encode(task_config(parent),
         mms_task_sim_settings(parent), parent->id, tx_id);
built and installed the new RPMs, and it immediately fixed my problem.
when not on wifi, MMS now works consistently first try, though of course without ack.
also, i am now almost certain that MMS never works when i am on wifi.
Using shar might be easier.
i suppose that’s the standard for silly things like developer forums without any way to attach log files, but i personally never liked shar. the uuencode nonsense it uses has `s all over the place. its scary to paste into a terminal, plus it’s easy to hide malicious code in them. just my own weird take, i guess
Do you have ‘Send read receipts’ turned on in Settings > Apps > Messages > MMS? Does disabling that help (using the original mms-engine)?
read-receipts was turned off for every test above. i did try turning it on once a few days ago, and it did seem to change the output of mms-engine, but it didn’t make MMS work any better or any worse, as far as i could tell.
