MicroG - Playstore apps not working anymore in 2026
Hi,
all of a sudden some apps like Parkingpay are not working anymore complaining about some Playstore problem. I can’t even recall having installed Playstore. I recall having installed MicroG, instead. Any idea out there? Some new incompatibiliy caused by the new year / version / whatever ? I installed them via FDroid / Aurora
Thanks
No, no idea. I think its helpful, if you open a thread for the apps not working anymore. And also it would be helpful to know which phone you use (and perhaps which SFOS-Version).
One example why more information are necessary could be the apps need Android-13 now and you have a Xperia 10iii, whose App-Support is stuck on version 11.
It’s C2 Tampella 5.0.0.72 IIRC. But I upgraded it today because it was not working, having the previous version installed.
Might also help to list the microG version you have installed on you phone.
