You can direct download the apk and install internal.
Did you enable signature spoofing in Prefs > Android App Support?
Thank you @eson
I am able to install the microg apps. do i need to install all of them ?
I have no idea, I guess it depends on what you want to achieve.
So I followed the tutorial, and only installed the 4 apps from the MicroG repo. Things seems to be working fine, except Signature Spoofing. And I noticed the battery usage did increase, I will confirm later. (I could end the day in 50%, we’ll see if that is similar now with MicroG)
Discord now shows notifications. Haven’t tried any apps that make use of location.
I liked the most. So, from FDroid:
o Déjà Vu
Mobile/cell and WLAN/Wi-Fi based network provider for UnifiedNlp and microG
o Nominatim
UnifiedNlp geocoding provider (MapQuest Nominatim)
o FakeStore
microG Store (FakeStore release)
o Local GSM Location - A local cell tower based back
UnifiedNlp location provider (local GSM database)
Can’t find that here. Do you mean Sailfish Settings > Android App Support?
There is “Disable Android AppSupport system package verification”. Is that the same as signature spoofing?
Yes. (20 characters)
