I just bought and flashed Xperia 10 II but can’t get MicroG to work. I’ve enabled signature spoofing from Sailfish Settings, installed F-droid and MicroG Services Core etc…
But the problem is that in Android settings I would need to allow “enable system package replacement” for them, but it shows “0 of 0 apps allowed”. So I can’t allow them and thus they can’t work?
Anyone else ran into that or knows a solution to this?
This is a bit annoying as I do need some applications that require Google Services.
I get it work on my Xperia 10 II. After enabling signature spoofing in Sailfish settings, tap on microg settings → self check → System grants Signature spoofing permission.
Hello ! @ajalkane and @jumPM which were the initial steps, only F-droid and there the MicroG services .Just can’t remember what I did with XA2 years ago. Is there already AD-control for 64-bit platform, I can’t find it from openrepos? need to buikd 10-II to main driver, XA2 has some problems after update(browser and mail not runnig all else ok) , got recommendation from Zendesk to re-flash .
