Hi,
i have an account at mailbox.org. i have my contacts there, that i did sync once.
once cause the upload sync fucked up some contacts and downloadsync deletes the fav information.
however i did receice a call yesterday from andreas s, i pick up, it was andreas g.
when i look at the contact it shows andreas s, also in history, when i say edit i can choose from 5 contacts
if i select andreas s, i see only the correct details of him
when i select andreas g, deto
when i select astrid l deto
so somehow these 5 contacts belong together on the phone, not in my cloud adress book. most of them do not exist any longer in the cloud. e.g. andreas s is not in my cloud adress book.
how could i check and fix that ?
cheers
jan
This tutorial may help you and give you some hint: Moving a contact in another addressbook on Sailfish OS
And I found this bug report: Contact messed up
Can you confirm it’s the same?
Would say so, yesss seems very likely to be the case
