Meecast shows Moon Icon instead of Sun icon
Recently Meecast in Event View is only showing the Moon icon and not the Sun icon. It’s as if Meecast thinks it’s night time even in the day time.
I am in New Zealand and we currently are in daylight (summer) time.
Are u sure, your Location and Time Zone are set correct? In SailfishOS and in MeeCast? Sure that MeeCast can update weather data without Problems?
If anything is correct - i would ask MeeCast Author and create Bug request.
…, i.e. here: Issues · Meecast/meecast · GitHub
P.S.: More specifically, if this is reproducible (across reboots etc.) for you and you did not find a setting which is the culprit (despite searching in MeeCast’s and the SailfishOS settings app for a misconfiguration causing this, e.g. a wrong time-zone or an incorrect time set), do search if an issue addressing this is already filed, then you might ask the MeeCast Author [Vasvlad] by creating an issue report.
