Since J doesn’t look into it, I had a thought on implementing disabling finger-print scanner on double-clicking the power button: currently it locks the device.
Powerkey press from display on:
single blank,tklock
double blank,tklock,devlock,vibrate
long dbus1
Powerkey D-Bus actions:
dbus1 send signal with arg 'power-key-menu'
dbus2 send signal with arg 'event2'
dbus3 send signal with arg 'event3'
dbus4 send signal with arg 'event4'
dbus5 send signal with arg 'event5'
dbus6 send signal with arg 'event6'
dbus7 send signal with arg 'event7'
dbus8 send signal with arg 'event8'
dbus9 send signal with arg 'event9'
dbus10 send signal with arg 'event10'
Browsing through powerkey.c · master · mer-core / mce · GitLab I’ve noticed that there are some pwrkey_dbus_action[] actions than MCE could send.
Is that possible to make power-key-double-click send such an action, so that the daemon I write would listen to it and then kill finger-print scanner daemon?
Should work, right? Adding dbus5, for example, so double looks like blank,tklock,devlock,dbus5,vibrate
PS And we can even edit the exact signal
mcetool --set-powerkey-dbus-action=5,my-dbus-signal555
