Mc workaround for opening tar.gz on 5.2.0.17
Looks like mc can no longer enter tar.gz archives on 5.2.0.17, this workaround seems to work:
devel-su cp -a /etc/mc/mc.ext.ini /etc/mc/mc.ext.ini.bak
devel-su sed '/Regex=/s/\\/\\\\/g' -i /etc/mc/mc.ext.ini
That was with gnu sed, no idea if busybox sed works (‘pkcon remove busybox-symlinks-sed’ to get real sed). Found here: [SOLVED] mc stopped to enter compressed tars / Applications & Desktop Environments / Arch Linux Forums it’s supposedly linked to glib2 issue, but ours is much newer than reported there and still happens, so no idea, maybe another regression, but the workaround works
you throw away the ‘.ini’ in the 2nd command. :wink:
Thanks, fixed
20202020
McWorkaround
You want some fries with that?
