REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.21
HARDWARE: C2
UI LANGUAGE: English (US)
REGRESSION:
The maximum brightness is too low (it feels) and certainly lower than what it is when the “Adjust brightness automatically” option is active.
An Jolla C2 device with SailfishOS 5.0.0.21
- Go to Settings > Display
- Regardless of the state of the option “Adjust brightness automatically”, toogle it !
- Observe the unexpected behavior for when the option is not active : the brightness level is/might be lower than what it should be !
Manual adjustment of the brightness level in its maximum should give maximum display brightness.
Manual adjustment of the brightness level in its maximum does not give maximum display brightness.
None that I am aware of.
None
