REPRODUCIBILITY: Always
OS VERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 II - Dual SIM
UI LANGUAGE: German
REGRESSION: Maybe?
Markor version 2.12.5 and above from F-Droid crash when run in Android AppSupport, previous versions worked without issue.
Install Markor version 2.12.5 or above from F-Droid or GitHub.
- Launch the Markor app
- Complete tutorial
- Press “OK” in “Storage permission required to read and write files” dialog
- Press “Allow” in “Allow Markor to access photos and media on your device?” SFOS popup
- Swipe the “Allow access to manage all files” permission in opened Android settings
- Close Android settings
- Open Markor again
Markor main screen launches, showing local documents as seen by the Android environment
Markor crashes.
Some apps from OpenRepos, but nothing invasive.
Crash log of Markor 2.12.5
09-24 19:55:37.871 13 13 E cutils : Failed to mkdirat(/mnt/media_rw/8ff87de4-0b37-4799-b09a-82773e869e07/Android): Read-only file system
09-24 19:55:37.873 9179 9179 W ContextImpl: Failed to ensure /storage/8ff87de4-0b37-4799-b09a-82773e869e07/Android/data/net.gsantner.markor/files: android.os.ServiceSpecificException: (code -30)
09-24 19:55:37.855 175 376 I chatty : uid=1000(system) AlienService identical 2 lines
09-24 19:55:37.857 175 376 E AlienService: Failed to set drag resizing mode
09-24 19:55:37.906 175 226 W ActivityTaskManager: resizeTask not allowed on task=Task{e9ca8b #4175 visible=true type=standard mode=fullscreen translucent=false A=10039:de.danoeh.antennapod U=0 StackId=4175 sz=1}
09-24 19:55:37.907 175 226 W ActivityTaskManager: resizeTask not allowed on task=Task{60bcaae #4185 visible=true type=standard mode=fullscreen translucent=false A=1000:com.android.settings U=0 StackId=4185 sz=2}
09-24 19:55:38.022 13 13 E cutils : Failed to mkdirat(/mnt/media_rw/8ff87de4-0b37-4799-b09a-82773e869e07/Android): Read-only file system
09-24 19:55:38.023 9179 9247 W ContextImpl: Failed to ensure /storage/8ff87de4-0b37-4799-b09a-82773e869e07/Android/data/net.gsantner.markor/files: android.os.ServiceSpecificException: (code -30)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: FATAL EXCEPTION: pool-2-thread-1
09-24 19:55:38.198 9179 9247 E AndroidRuntime: Process: net.gsantner.markor, PID: 9179
09-24 19:55:38.198 9179 9247 E AndroidRuntime: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.String java.io.File.getAbsolutePath()' on a null object reference
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserListAdapter.lambda$loadFolder$9(Unknown Source:330)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserListAdapter.$r8$lambda$TWVJW-w70YRy2cjUS49nudys7G4(SourceFile:0)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserListAdapter$$ExternalSyntheticLambda1.run(SourceFile:0)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
09-24 19:55:38.198 9179 9247 E AndroidRuntime: at java.lang.Thread.run(Thread.java:923)
09-24 19:55:37.908 175 226 I chatty : uid=1000(system) android.display identical 1 line
09-24 19:55:37.909 175 226 W ActivityTaskManager: resizeTask not allowed on task=Task{60bcaae #4185 visible=true type=standard mode=fullscreen translucent=false A=1000:com.android.settings U=0 StackId=4185 sz=2}
09-24 19:55:38.209 175 9252 I DropBoxManagerService: add tag=data_app_crash isTagEnabled=true flags=0x2
09-24 19:55:38.209 175 430 W ActivityTaskManager: Force finishing activity net.gsantner.markor/.activity.MainActivity
09-24 19:55:38.259 9179 9247 I Process : Sending signal. PID: 9179 SIG: 9
Crash log of latest Markor nightly
09-24 20:13:43.374 13 19 E cutils : Failed to mkdirat(/mnt/media_rw/8ff87de4-0b37-4799-b09a-82773e869e07/Android): Read-only file system
09-24 20:13:43.375 9795 9795 W ContextImpl: Failed to ensure /storage/8ff87de4-0b37-4799-b09a-82773e869e07/Android/data/net.gsantner.markor_test/files: android.os.ServiceSpecificException: (code -30)
09-24 20:13:43.465 13 19 E cutils : Failed to mkdirat(/mnt/media_rw/8ff87de4-0b37-4799-b09a-82773e869e07/Android): Read-only file system
09-24 20:13:43.466 9795 9795 W ContextImpl: Failed to ensure /storage/8ff87de4-0b37-4799-b09a-82773e869e07/Android/data/net.gsantner.markor_test/files: android.os.ServiceSpecificException: (code -30)
09-24 20:13:43.469 9795 9795 D AndroidRuntime: Shutting down VM
09-24 20:13:43.494 9795 9795 E AndroidRuntime: FATAL EXCEPTION: main
09-24 20:13:43.494 9795 9795 E AndroidRuntime: Process: net.gsantner.markor_test, PID: 9795
09-24 20:13:43.494 9795 9795 E AndroidRuntime: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.String java.io.File.getName()' on a null object reference
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserListAdapter.getVirtualFolders(GsFileBrowserListAdapter.java:154)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserListAdapter.<init>(GsFileBrowserListAdapter.java:138)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at net.gsantner.opoc.frontend.filebrowser.GsFileBrowserFragment.onViewCreated(GsFileBrowserFragment.java:125)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.Fragment.performViewCreated(Fragment.java:2987)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.FragmentStateManager.createView(FragmentStateManager.java:546)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.FragmentStateManager.moveToExpectedState(FragmentStateManager.java:282)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.FragmentManager.executeOpsTogether(FragmentManager.java:2189)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.FragmentManager.removeRedundantOperationsAndExecute(FragmentManager.java:2100)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.FragmentManager.execSingleAction(FragmentManager.java:1971)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.fragment.app.BackStackRecord.commitNow(BackStackRecord.java:305)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.viewpager2.adapter.FragmentStateAdapter.placeFragmentInViewHolder(FragmentStateAdapter.java:341)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.viewpager2.adapter.FragmentStateAdapter.onViewAttachedToWindow(FragmentStateAdapter.java:276)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.viewpager2.adapter.FragmentStateAdapter.onViewAttachedToWindow(FragmentStateAdapter.java:67)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.dispatchChildAttached(RecyclerView.java:7867)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$5.addView(RecyclerView.java:893)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.ChildHelper.addView(ChildHelper.java:107)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$LayoutManager.addViewInt(RecyclerView.java:8902)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$LayoutManager.addView(RecyclerView.java:8860)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$LayoutManager.addView(RecyclerView.java:8848)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.LinearLayoutManager.layoutChunk(LinearLayoutManager.java:1645)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.LinearLayoutManager.fill(LinearLayoutManager.java:1591)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.LinearLayoutManager.onLayoutChildren(LinearLayoutManager.java:668)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.dispatchLayoutStep2(RecyclerView.java:4309)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.dispatchLayout(RecyclerView.java:4012)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.onLayout(RecyclerView.java:4578)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at android.view.View.layout(View.java:22844)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at android.view.ViewGroup.layout(ViewGroup.java:6389)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at androidx.viewpager2.widget.ViewPager2.onLayout(ViewPager2.java:527)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at android.widget.FrameLayout.layoutChildren(FrameLayout.java:332)
09-24 20:13:43.494 9795 9795 E AndroidRuntime: at android.widget.FrameLayout.onLayout(FrameLayout.java:270)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.widget.FrameLayout.layoutChildren(FrameLayout.java:332)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.widget.FrameLayout.onLayout(FrameLayout.java:270)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at com.android.internal.policy.DecorView.onLayout(DecorView.java:787)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.View.layout(View.java:22844)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.ViewGroup.layout(ViewGroup.java:6389)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:3470)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2938)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1952)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:8171)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.Choreographer$CallbackRecord.run(Choreographer.java:972)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.Choreographer.doCallbacks(Choreographer.java:796)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.Choreographer.doFrame(Choreographer.java:731)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:957)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:938)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:99)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.os.Looper.loop(Looper.java:223)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:7656)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:599)
09-24 20:13:43.496 9795 9795 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
09-24 20:13:43.519 175 9870 I DropBoxManagerService: add tag=data_app_crash isTagEnabled=true flags=0x2
09-24 20:13:43.521 175 4044 W ActivityTaskManager: Force finishing activity net.gsantner.markor_test/net.gsantner.markor.activity.MainActivity
09-24 20:13:43.647 9795 9795 I Process : Sending signal. PID: 9795 SIG: 9
09-24 20:13:43.647 175 223 W Looper : Slow dispatch took 107ms android.fg h=com.android.server.DropBoxManagerService$DropBoxManagerBroadcastHandler c=null m=1
09-24 20:13:43.682 9057 9071 W System : A resource failed to call release.
09-24 20:13:43.747 41 41 I Zygote : Process 9795 exited due to signal 9 (Killed)
The diff between Markor 2.12.4 and 2.12.5 is rather small.
It’s not clear from the log if this is something Markor does wrong or Android AppSupport. Any ideas?
