Here’s a long AAS logcat I got just now. I started with rebooting the phone. The first thing I did after that was Settings → Apps → Seafile (Android app) → Open Android settings. I looked at the permissions, backed out and eventually closed the settings window.
I copied the log from when the com.seafile.seadroid2 appeared in the logcat. The timestamp matched the time, when I opened the settings.
By the time I cut the log, installd had eaten ~25% of memory.
Way too much log. Can’t fit it all to this post.
06-03 20:03:59.964 265 278 I AlienService: Querying background services for package com.seafile.seadroid2
06-03 20:04:01.166 265 371 E WificondScannerImpl: Timed out waiting for scan result from wificond
06-03 20:04:01.417 508 551 D AppSupportBridge:IntentResolverService: startActivityFromIntent
06-03 20:04:01.420 265 278 I ActivityTaskManager: START u0 {act=android.settings.APPLICATION_DETAILS_SETTINGS dat=package:com.seafile.seadroid2 flg=0x10008000 pk
g=com.android.settings cmp=com.android.settings/.applications.InstalledAppDetails} from uid 1000
06-03 20:04:01.435 265 280 D system_server: NEW TASK: nullcomponent
06-03 20:04:01.438 265 280 D system_server: NEW TASK: com.android.settings
06-03 20:04:01.448 421 421 D FakeHome: onPause
06-03 20:04:01.451 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(5) is always true
06-03 20:04:01.451 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(1) is always true
06-03 20:04:01.451 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(4) is always true
06-03 20:04:01.451 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(3) is always true
06-03 20:04:01.451 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(2) is always true
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: getSwitchState is not supported
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(5) is always true
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(1) is always true
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(4) is always true
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(3) is always true
06-03 20:04:01.452 265 278 W AlienEventHub: APPSUPPORT: isDeviceEnabled(2) is always true
06-03 20:04:01.456 265 280 D system_server: ALIEN: MOVED KNOWN TASK: 2 0 com.jolla.home
06-03 20:04:01.456 265 280 D system_server: ALIEN: MOVED KNOWN TASK: 19879 1 com.android.settings
06-03 20:04:01.458 508 551 D AppSupportAudioControlService: internalPackageFocused com.android.settings
06-03 20:04:01.459 508 551 D AppSupportAudioControlService: onRaiseWindow: com.android.settings
06-03 20:04:01.460 508 551 D AppSupportAudioControlService: onRaiseWindow: com.android.settings
06-03 20:04:01.461 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:01.462 265 311 I chatty : uid=1000(system) OomAdjuster identical 11 lines
06-03 20:04:01.462 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:01.463 265 287 W System : ClassLoader referenced unknown path:
06-03 20:04:01.467 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:01.469 265 311 I chatty : uid=1000(system) OomAdjuster identical 21 lines
06-03 20:04:01.469 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:01.506 971 971 D SettingsActivity: Starting onCreate
06-03 20:04:01.547 971 971 D SettingsActivity: Starting to set activity title
06-03 20:04:01.547 971 971 D SettingsActivity: Done setting title
06-03 20:04:01.547 971 971 D SettingsActivity: Switching to fragment com.android.settings.applications.appinfo.AppInfoDashboardFragment
06-03 20:04:01.550 265 280 D SurfaceFlinger: NEW BUFFER
06-03 20:04:01.556 421 611 D EglHelper: createEglContext start
06-03 20:04:01.557 421 611 D EglHelper: createEglContext done
06-03 20:04:01.557 421 611 D EglHelper: createEglSurface start
06-03 20:04:01.558 421 611 D EglHelper: createEglSurface done
06-03 20:04:01.577 265 280 I system_server: new app: com.android.settings:1000:19879:1080x2520
06-03 20:04:01.580 265 280 I system_server: ALIEN: notifying app opened com.android.settings
06-03 20:04:01.580 265 352 I InputReader: Device removed: id=5, eventHubId=3, name='alien_wayland_pointer', descriptor='', sources=0x00001002
06-03 20:04:01.580 265 352 W AlienEventHub: APPSUPPORT: getDeviceControllerNumber is not supported
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: setKeyboardLayoutOverlay is not supported
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: isDeviceEnabled(3) is always true
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: hasRelativeAxis is not supported
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: hasScanCode is not supported
06-03 20:04:01.581 265 352 I chatty : uid=1000(system) InputReader identical 4 lines
06-03 20:04:01.581 265 352 I InputReader: Device reconfigured: id=9, name='alien_wayland_pointer', size 1081x2521, orientation 0, mode 1, display id 0
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: getVirtualKeyDefinitions is not supported
06-03 20:04:01.581 265 352 I InputReader: Device added: id=9, eventHubId=3, name='alien_wayland_pointer', descriptor='',sources=0x00001002
06-03 20:04:01.581 265 352 I InputReader: Device removed: id=6, eventHubId=4, name='alien_wayland_touch', descriptor='', sources=0x00001002
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: getDeviceControllerNumber is not supported
06-03 20:04:01.581 265 352 W AlienEventHub: APPSUPPORT: isDeviceEnabled(4) is always true
06-03 20:04:01.581 265 352 I InputReader: Device reconfigured: id=10, name='alien_wayland_touch', size 1081x2521, orientation 0, mode 1, display id 0
06-03 20:04:01.581 265 352 I InputReader: Device added: id=10, eventHubId=4, name='alien_wayland_touch', descriptor='',sources=0x00001002
06-03 20:04:01.592 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppNotificationPrefer
enceController
06-03 20:04:01.594 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppPermissionPreferen
ceController
06-03 20:04:01.594 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppStoragePreferenceC
ontroller
06-03 20:04:01.595 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.InstantAppDomainsPref
erenceController
06-03 20:04:01.595 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppDataUsagePreferenc
eController
06-03 20:04:01.596 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.TimeSpentInAppPrefere
nceController
06-03 20:04:01.596 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppOpenByDefaultPrefe
renceController
06-03 20:04:01.598 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AdvancedAppInfoPrefer
enceCategoryController
06-03 20:04:01.598 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.DrawOverlayDetailPref
erenceController
06-03 20:04:01.598 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.WriteSystemSettingsPr
eferenceController
06-03 20:04:01.599 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.specialaccess.pictureinpictur
e.PictureInPictureDetailPreferenceController
06-03 20:04:01.599 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.ExternalSourceDetailP
referenceController
06-03 20:04:01.599 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.specialaccess.interactacrossp
rofiles.InteractAcrossProfilesDetailsPreferenceController
06-03 20:04:01.600 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppInstallerPreferenc
eCategoryController
06-03 20:04:01.600 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppInstallerInfoPrefe
renceController
06-03 20:04:01.601 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppSettingPreferenceC
ontroller
06-03 20:04:01.601 971 971 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.applications.appinfo.AppVersionPreferenceC
ontroller
06-03 20:04:01.613 265 280 I system_server: ALIEN: raising window: com.android.settings
06-03 20:04:01.617 265 280 D SurfaceFlinger: NEW BUFFER
06-03 20:04:01.650 971 971 W InstrumentedPrefFrag: Screen title missing for fragment com.android.settings.applications.appinfo.AppInfoDashboardFragment
06-03 20:04:01.650 265 280 D SurfaceFlinger: NEW BUFFER
06-03 20:04:01.680 971 971 D AppInfoDashboard: NO dashboard tiles for AppInfoDashboard
06-03 20:04:01.682 971 971 D AppInfoDashboard: All preferences added, reporting fully drawn
06-03 20:04:01.685 971 971 D SettingsActivity: Executed frag manager pendingTransactions
06-03 20:04:01.726 971 971 W AppButtonsPrefCtl: App is not explicitly stopped
06-03 20:04:01.729 971 1261 I TetheringManager: registerTetheringEventCallback:com.android.settings
06-03 20:04:01.733 971 990 D TelephonyRegistryManager: onSubscriptionsChangedListener callback received.
06-03 20:04:01.745 971 1262 D SettingsActivity: No enabled state changed, skipping updateCategory call
06-03 20:04:01.750 265 312 D BatteryStatsImpl: Got readings for an invalid user's uid 100000
06-03 20:04:01.750 265 312 D KernelCpuUidUserSysTimeReader: Removing uids 100000-100000
06-03 20:04:01.752 265 312 E KernelCpuUidFreqTimeReader: Negative delta from freq time proc: -10
06-03 20:04:01.752 265 312 E KernelCpuUidFreqTimeReader: Negative delta from freq time proc: -290
06-03 20:04:01.753 265 312 E KernelCpuUidClusterTimeReader: Negative delta from cluster time proc: -70
06-03 20:04:01.755 971 971 W UnsafeUtil: platform method missing - proto runtime falling back to safer methods: java.lang.NoSuchMethodException: sun.misc.Unsafe.
copyMemory [class java.lang.Object, long, class java.lang.Object, long, long]
06-03 20:04:01.764 971 991 I ndroid.setting: Waiting for a blocking GC ProfileSaver
06-03 20:04:01.779 265 312 W BatteryExternalStatsWorker: modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTransmitPowerInfo[]
=[TransmitPower{ mTimeInMillis=0 mPowerRangeInDbm={-2147483648,0}}, TransmitPower{ mTimeInMillis=0 mPowerRangeInDbm={0,5}}, TransmitPower{ mTimeInMillis=0 mPowerRang
eInDbm={5,15}}, TransmitPower{ mTimeInMillis=0 mPowerRangeInDbm={15,20}}, TransmitPower{ mTimeInMillis=0 mPowerRangeInDbm={20,2147483647}}] mRxTimeMs=0}
06-03 20:04:01.837 265 279 E IntervalStats: Unable to parse usage stats package 1
06-03 20:04:01.889 971 971 D AppUtils: Have 0 number of activities in preferred list
06-03 20:04:01.990 971 971 W AppButtonsPrefCtl: App is not explicitly stopped
06-03 20:04:02.003 265 279 D CompatibilityChangeReporter: Compat change id reported: 136274596; UID 1000; state: ENABLED
06-03 20:04:02.007 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:02.041 265 279 E IntervalStats: Unable to parse usage stats package 1
06-03 20:04:02.008 265 311 I chatty : uid=1000(system) OomAdjuster identical 10 lines
06-03 20:04:02.008 265 311 E libprocessgroup: set_timerslack_ns write failed: Operation not permitted
06-03 20:04:02.082 971 971 W ControllerTask: The updateState took 66 ms in Controller AppNotificationPreferenceController
06-03 20:04:02.088 971 971 D AppUtils: Have 0 number of activities in preferred list
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: QUALCOMM build : 704ecd9a2b, Ib3f3e69395
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Build Date : 12/29/20
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: OpenGL ES Shader Compiler Version: EV031.32.02.06
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Local Branch :
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Remote Branch :
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Reconstruct Branch :
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Build Config : S P 10.0.7 AArch64
06-03 20:04:02.132 971 1251 I AdrenoGLES-0: Driver Path : /odm/lib64/egl/libGLESv2_adreno.so
06-03 20:04:02.136 11 11 I hwservicemanager: getTransport: Cannot find entry android.hardware.graphics.mapper@4.0::IMapper/default in either framework or devic
e manifest.
06-03 20:04:02.137 11 11 I hwservicemanager: Since android.hardware.graphics.mapper@4.0::IMapper/default is not registered, trying to start it as a lazy HAL.
06-03 20:04:02.137 971 1251 E HidlServiceManagement: android.hardware.graphics.mapper@4.0
06-03 20:04:02.140 11 1272 W libc : Unable to set property "ctl.interface_start" to "android.hardware.graphics.mapper@4.0::IMapper/default": error code: 0x20
06-03 20:04:02.146 971 1261 W CpuPowerCalculator: UID 0 CPU cluster # mismatch: Power Profile # 1 actual # 2
06-03 20:04:02.146 971 1261 W CpuPowerCalculator: UID 74 CPU cluster # mismatch: Power Profile # 1 actual # 2
06-03 20:04:02.146 971 1261 W CpuPowerCalculator: UID 82 CPU cluster # mismatch: Power Profile # 1 actual # 2
06-03 20:06:25.322 73 339 I scudo : Scudo OOM: The process has Exhausted 256M for size class 1648.
06-03 20:06:28.584 265 274 I system_server: Background young concurrent copying GC freed 67827(3976KB) AllocSpace objects, 66(2008KB) LOS objects, 34% free, 11MB
/17MB, paused 84us total 191.732ms
06-03 20:06:28.660 265 276 W System : A resource failed to call release.
06-03 20:06:32.326 265 371 E WificondScannerImpl: Timed out waiting for scan result from wificond
06-03 20:06:32.924 265 330 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:32.925 265 330 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.056 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.056 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.056 515 515 I Telephony: isRoaming: false
06-03 20:06:33.056 515 515 I Telephony: isOnWfc: false
06-03 20:06:33.247 265 330 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:33.248 265 330 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.286 515 515 D ServiceStateProvider: subId=1
06-03 20:06:33.372 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:33.373 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.382 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.382 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.382 515 515 I Telephony: isRoaming: false
06-03 20:06:33.382 515 515 I Telephony: isOnWfc: false
06-03 20:06:33.461 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.461 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.461 515 515 I Telephony: isRoaming: false
06-03 20:06:33.461 515 515 I Telephony: isOnWfc: false
06-03 20:06:33.474 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:33.477 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.480 515 515 D ServiceStateProvider: subId=1
06-03 20:06:33.493 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.493 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.493 515 515 I Telephony: isRoaming: false
06-03 20:06:33.493 515 515 I Telephony: isOnWfc: false
06-03 20:06:33.678 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:33.678 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.684 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.684 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.684 515 515 I Telephony: isRoaming: false
06-03 20:06:33.684 515 515 I Telephony: isOnWfc: false
06-03 20:06:33.892 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of fine but the app-ops permission is specifically denied.
06-03 20:06:33.893 265 633 I LocationAccessPolicy: org.thoughtcrime.securesms is aware of coarse but the app-ops permission is specifically denied.
06-03 20:06:33.897 515 515 D ServiceStateProvider: subId=1
06-03 20:06:33.906 515 515 I Telephony: isRttCurrentlySupported -- regular acct, hasVoiceAvailability: false
06-03 20:06:33.906 515 515 I Telephony: isRttSupported: false
06-03 20:06:33.906 515 515 I Telephony: isRoaming: false
06-03 20:06:33.906 515 515 I Telephony: isOnWfc: false
06-03 20:06:37.224 73 339 I scudo : Stats: SizeClassAllocator64: 1793M mapped (0M rss) in 2686558 allocations; remains 2682642
06-03 20:06:37.224 73 339 I scudo : 00 ( 128): mapped: 256K popped: 238 pushed: 182 inuse: 56 total: 168 rss: 0K releases: 0 l
ast released: 0K region: 0x6f484a9000 (0x6f484a6000)
06-03 20:06:37.224 73 339 I scudo : 01 ( 32): mapped: 256K popped: 14 pushed: 0 inuse: 14 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6f584ae000 (0x6f584a6000)
06-03 20:06:37.224 73 339 I scudo : 02 ( 48): mapped: 256K popped: 70 pushed: 0 inuse: 70 total: 112 rss: 0K releases: 0 l
ast released: 0K region: 0x6f684b1000 (0x6f684a6000)
06-03 20:06:37.224 73 339 I scudo : 03 ( 64): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6f784ad000 (0x6f784a6000)
06-03 20:06:37.224 73 339 I scudo : 04 ( 80): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6f884b4000 (0x6f884a6000)
06-03 20:06:37.224 73 339 I scudo : 05 ( 96): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6f984af000 (0x6f984a6000)
06-03 20:06:37.224 73 339 I scudo : 06 ( 112): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6fa84b2000 (0x6fa84a6000)
06-03 20:06:37.224 73 339 I scudo : 07 ( 144): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6fb84a7000 (0x6fb84a6000)
06-03 20:06:37.224 73 339 I scudo : 08 ( 176): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6fc84b3000 (0x6fc84a6000)
06-03 20:06:37.224 73 339 I scudo : 10 ( 224): mapped: 256K popped: 28 pushed: 0 inuse: 28 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6fe84b5000 (0x6fe84a6000)
06-03 20:06:37.225 73 339 I scudo : 11 ( 288): mapped: 256K popped: 56 pushed: 0 inuse: 56 total: 56 rss: 0K releases: 0 l
ast released: 0K region: 0x6ff84b1000 (0x6ff84a6000)
06-03 20:06:37.225 73 339 I scudo : F 12 ( 352): mapped: 261888K popped: 765538 pushed: 3682 inuse: 761856 total: 761856 rss: 0K releases: 3 l
ast released: 16K region: 0x70084b4000 (0x70084a6000)
06-03 20:06:37.225 73 339 I scudo : F 13 ( 448): mapped: 261888K popped: 598601 pushed: 0 inuse: 598601 total: 598601 rss: 0K releases: 0 l
ast released: 0K region: 0x70184b2000 (0x70184a6000)
06-03 20:06:37.225 73 339 I scudo : F 14 ( 592): mapped: 261888K popped: 452995 pushed: 0 inuse: 452995 total: 452995 rss: 0K releases: 0 l
ast released: 0K region: 0x70284a8000 (0x70284a6000)
06-03 20:06:37.225 73 339 I scudo : F 15 ( 800): mapped: 261888K popped: 335208 pushed: 0 inuse: 335208 total: 335208 rss: 0K releases: 0 l
ast released: 0K region: 0x70384a7000 (0x70384a6000)
06-03 20:06:37.225 73 339 I scudo : F 16 ( 1104): mapped: 261888K popped: 242910 pushed: 0 inuse: 242910 total: 242910 rss: 0K releases: 0 l
ast released: 0K region: 0x70484ac000 (0x70484a6000)
06-03 20:06:37.225 73 339 I scudo : F 17 ( 1648): mapped: 261888K popped: 162726 pushed: 0 inuse: 162726 total: 162726 rss: 0K releases: 0 l
ast released: 0K region: 0x70584ae000 (0x70584a6000)
06-03 20:06:37.225 73 339 I scudo : F 18 ( 2096): mapped: 261888K popped: 127945 pushed: 0 inuse: 127945 total: 127945 rss: 0K releases: 0 l
ast released: 0K region: 0x70684af000 (0x70684a6000)
06-03 20:06:37.225 73 339 I scudo : 20 ( 3120): mapped: 256K popped: 2 pushed: 0 inuse: 2 total: 8 rss: 0K releases: 0 l
ast released: 0K region: 0x70884ac000 (0x70884a6000)
06-03 20:06:37.225 73 339 I scudo : 21 ( 4112): mapped: 256K popped: 2 pushed: 0 inuse: 2 total: 4 rss: 0K releases: 0 l
ast released: 0K region: 0x70984a8000 (0x70984a6000)
06-03 20:06:37.225 73 339 I scudo : 22 ( 4624): mapped: 256K popped: 57 pushed: 52 inuse: 5 total: 8 rss: 0K releases: 3 l
ast released: 12K region: 0x70a84aa000 (0x70a84a6000)
06-03 20:06:37.225 73 339 I scudo : Scudo OOM: The process has Exhausted 256M for size class 2096.
