I have installed Pixelfed from Aurora store, but I can not login to my account. The process stops when a screen appears and the browser tries to access 127.0.0.1/45881. Has anyone had success login in to Pixelfed?
Yes, i use it regularly, are you sure you selected pixelfed instead of mastodon on the address screen?also, did you get the latest update from either chum or openrepos?
I think the issue is, you use the official Pixelfed Android app but performed the signin on the Sailfish Browser, which cannot pass the authentication back.
You need an Android Browser, e.g. https://play.google.com/store/apps/details?id=org.mozilla.focus to be installed and set as default during the signin process.
Or, as @247 suggested, you could use Tooter the native app for Pixelfed:
I already have Tooter installed! I didn’t know they where basically the same. Thanks.![]()
