REPRODUCIBILITY (% or how often): Always when device is locked with security code/fingerprint.
BUILD ID = OS VERSION (Settings > About product): Since 4.0 Koli (Bug existed before after 3.1 Seitseminem fixed with 3.2 Nuuksio
HARDWARE (XA2, X10, X10 II, …): Xcompact
UI LANGUAGE: German
DESCRIPTION: Since update (4.0) pulley shortcuts from lockscreen do not lead to the app but to events view after entering code/fingerprint. When going to homescreen, you can see that app has been started, but not opened. This is not the case if device hasn’t been locked, so the issue must be related to the entering of code/fingerprint. Has not been fixed with 4.1 or 4.2
Pulley shortcuts (in my case Phone, Contacts and Messages App) and device lock (when device is put to standby) have been chosen in settings
- Turn off device to standby mode by shortly pressing on/off button
- Turn on the device by shortly press the on/off button
- Lockscreen appears, use pulley menu to start an app.
- After chosing an app from pulley menu, the unlock page appears, enter code/fingerprint
After entering code/fingerprint to unlock, the selected App should start and open
After entering code/fingerprint to unlock, the eventsview opens
App has been started, but not opened
(Bug existed before after 3.1 Seitseminem fixed with 3.2 Nuuksio)
https://together.jolla.com/question/213544/pulley-shortcuts-from-lockscreen-do-not-work-properly-when-phone-is-locked/
