I am currently in the process of transitioning from an Android smartphone to a Jolla phone. I find myself missing a way to quickly lock the Jolla phone without having to press the button on the side. You might wonder why: mechanical components are prone to wear and tear, and I’ve always found the alternative locking methods available on Android to be quite practical. Here are two ideas:
double-tapping the home screen could lock the device.
the lock icon in the pull-down settings menu could become selectable (highlighted in blue), when the menu is pulled down, allowing you to lock the phone that way.
I think both options are great, though the second one might perhaps conflict slightly with the overall user interface concept.
well, you have no fail until you have one
Right, you can tap the lock, but it is something about usability and UX: the lock is quite on top and too far for my thumb and additionally, you have two “gestures”: pulling the menu and tap the lock –> i just would like to pull the menu slightly until the lock is selected…
sure, that is why I suggested double tap as well - and this is quite common at least on Samsung devices. I mean if you don’t like/need this, you don’t need to use it.
It’s my nightly currently
Double tap works (at least most of the attempts), that’s cool. But it’s hard to do it just with one hand/thumb. I guess, I need to figure out, how to make a pull request for the settings-lab. If anybody could help here, I appreciate it.
I would still say, that a double tap just above the bottom edge would be more handy (in addition to the top edge).
