Hey!
I have Xperia 10ii with paid Sfos, and I cant get the location working with any app.
What can I try?
Have you tried installing GPSLocator from Jolla Store?
In the app, at the lower right side, it shows the nr. of satellites detected (even if not connected yet).
That way, you will be able to see, at least, if your GPS is completely dead.
It finds 7 satellites, and gps seems to work properly, also compass works.
But Google maps or pure maps doesnt find any location
I’m using a X10ii and the GPS is working well in mode “without connexion” (in french words “Mode sans connexion réseau”) but sometimes I have to wait ~10 minutes before localization.
… And don’t forget to calibrate the compass !
Location started to work suddenly, but how can you calibrate the compass?
Launch “CSD Tools” (just tap many tes on the version # on the system infos “About product”)…
and then in “individuaks tests”, you can choose “Compass”.
