Thank you! I’ve been missing this app for years.
Thank you for this great App
Cauko… hele na 5ku nainstalovano uplne v pohode
Dokonce aji DB jsem pretahl… coooll miluju te kaaamo
EDIT (translation):
Hi… Finally installed on my Xperia 10 V.
Database restored from my Xperia XA2 without any problem.
Cool I love you bro…
PS: Sorry for Czech, I thought I wrote PM to koza…
Translation server error.
cover page has been fixed in 1.3.3-1 SailTaskList | OpenRepos.net — Community Repository System
v1.3.4 - added Search in Task list (useful for long task lists)
https://openrepos.net/content/kozaobecna/sailtasklist
Some years ago I contacted the developer and asked for search ability. He replied that this wasn’t possible and he wasn’t maintain any more the app. So thank you for this add koza!
I installed your version and unfortunately I lost all my lists. The app I had was a from my own compilation of the source code for xperia 10 iii. I will check if the problem is with paths or something else.
Follow instructions, DB has moved to different directory
Copy it from older to newer one and your list will be back…
And… @koza is the BEST :-* <3
copy
~ /.local/share/harbour-sailtasklist/harbour-sailtasklist/QML/OfflineStorage/Databases/*
to
~/.local/share/org.myorg/harbour-sailtasklist/QML/OfflineStorage/Databases/
Hey koza,
thank you very much for providing and maintaining the app. Makes my life easier. It fits my needs nearly to 100%. However, I have maybe one small wish if it is possible to realise at all.
I have a list with like 100 items. All of the items are marked as solved. When I uncheck an item at position 65 the list jumps to position 11. Is it possible to stay at the very same display position. So I can uncheck e.g. item 67 without scrolling back to that point?
I see… I can reproduce this issue on recent SFOS, not on old jolla phone 1 where I have the same version of Lists and it is working without this scrolling bug, so will try to look if can fix it somehow
anyway now while testing i got idea to add to puley menu “Incomplete all tasks” it could be useful too
it looks like that on old phone UI does not refresh quickly or something else related to page rendering…, that is why this was working fine on old Jolla…
in more details: app does this in following steps when you click on Task: change status of task (save to db), clear taskList (ListView component) and then it will load back updated taskList from db. Somewhere between these steps it just ‘ignoring’ moment when ListView having zero items and that is why it is still on same place on old Jolla. In short UI ListView having still same height so no scroll to top…
but
New faster phone or changes in SFOS (who knows) doing refresh of UI instantly so on clearing list it shrink view and then it just scroll to top
Well fix could be about to change way how to handle tasks - not clearing and reloading taskList but just saving changes to db, changing task name visually and move/reorder task in list to completed/uncompleted section but as there are also abc/older/newer sorting, sounds like complicated solution
instead i will track index of task: you click on “65” and after steps mentioned above it will scroll view to the next item so “66” will be first visible item…
https://openrepos.net/sites/default/files/packages/18865/harbour-sailtasklist-1.3.5-1.armv7hl.rpm
https://openrepos.net/sites/default/files/packages/18865/harbour-sailtasklist-1.3.5-1.aarch64.rpm
Thank you very much. This is awesome
