Lineage based port for Xperia 10 V (zambezi)
This is the way I did it on Murray, and the way I had Zambezi briefly working at one point - but when I went to package up the changes it all fell over.
I’ll give it a try and see if it wants to play ball, thanks.
Hey @zerocal,
Are your findings from this post based on this port or the Jolla port?
We already have android.hardware.gatekeeper.IGatekeeper/default, and we already have /var/lib/sailfish-fpd. I was not planning on using the AIDL side of things at all - rather, I was trying to get android.hardware.biometrics.fingerprint@2.1 back up and running. Does your phone have that?
My work to date was more along the lines of what @parth007 is talking about. I had overlayed blobs from the stock Android 14 /vendor partition onto the Lineage Android 15 equivalent and managed to get fingerprint working intermittently, but I’m yet to get it reliable and I’m not sure why. As I say, it’s difficult to debug over instant messaging.
Mine has @2.1::IBiometricsFingerprint on hwbinder via Sony’s stock @2.1-service, with only the HIDL gatekeeper@1.0.
If it works only sometimes, I’d check whether the HAL starts before qseecomd and the TA listeners are up, and what packaging loses versus your hand overlay (modes, VINTF entry for vendor.egistec.hardware.fingerprint@4.0, the /data/vendor_de/0/fpdata symlink, SELinux labels).
Happy to send my file list and rc to diff.
Hi @Sharks,
Sorry for the late reply.
My findings are from this port, not the Jolla one: xqdc72 on SFOS 5.2.0.22, droid-config-xqdc72 0.0.16, droid-hal-version-xqdc72 20260802.
On my phone:
/vendor/etc/vintf/manifest.xml only declares the HIDL gatekeeper (android.hardware.gatekeeper@1.0::IGatekeeper/default, gatekeeper@1.0-service-qti). android.hardware.gatekeeper.IGatekeeper/default was not registered, which is why the binder slave hung in ENUMERATING until I added the bridge. gatekeeperd is running, but that’s android.service.gatekeeper.IGateKeeperService, a different service.
The fingerprint HAL is the Lineage AIDL one (android.hardware.biometrics.fingerprint-service.lineage, IFingerprint v4). There is no android.hardware.biometrics.fingerprint@2.1 in the vendor manifest and nothing serving it. /vendor/lib64/hw/fingerprint.default.so is still there, so a @2.1 service on top of it might work.
/var/lib/sailfish-fpd was fine. The missing piece was /data/vendor_de/0/fpdata, where the Lineage HAL writes templates. Without it, enrolment cancelled at the last step.
So my route keeps the Lineage AIDL HAL as it is and bridges the gatekeeper. If you get @2.1 working reliably, that’s probably the cleaner option!
The two touch unlock has been working flawlessly for me since a week now :slight_smile:
This port continues to improve and turns the otherwise crippled 10V into a fantastic phone.
@Sharks has worked a lot on trying to get the fingerprint reader working well and reliably, and has found time yet again to improve the port by rolling in @zerocal’s solution to fix the fingerprint.
Following the update to be released very soon, my 10V has successfully enrolled multiple prints and unlock is surviving reboots and working flawlessly. This is absolutely fantastic and I really convenience feature - making the phone quicker and easier to use.
Thank you to @zerocal for finding a solution that works well and sharing it here. Thanks also to @parth007 for finding an alternate solution and sharing advice too. And of course, thanks @Sharks for again improving this great port. It is a joy to use.
I also want to share a quick example of how wonderful it is to have a solid port on the 10V. I recently went on a multinight bushwalking trip, and had the 10V with me. The ability to toggle flight mode on and off, and this working (unlike the Jolla port) was amazing. The phone suspended incredibly well with the screen off and flight mode on, thus battery life was amazing. A very little thing, but the experience on this port is a world away from how the Jolla port was when I moved across. Simply sharing to encourage others to move across if they can make do without AppSupport. The phone works wonderfully well in comparison to the official release. Thanks again @Sharks.
Hey @zerocal,
Thanks a bunch for your help. Without the device in front of me to actively debug on, I was really struggling to work out which piece of the puzzle I was missing. Your solution does indeed appear to work perfectly - and it is now part of the port. Existing users can now zypper ref; zypper dup, reboot their phones, and enroll their fingerprints!
I will have to investigate a similar solution when time permits for Murray and see if it solves the issue I have there where only one finger can be enrolled at a time.
Thanks again,
Sharks.
Awesome! Thanks for the great work @Sharks , @juz , @parth007 and everyone involved in this port. This phone, and the port is just incredible!
Sony Xperia 10 V (zambezi) does not have AppSupport yet, but Wadroid works perfectly well. For installation you need to execute two command lines, everything else is automated:
Dear users and developers,
Have anyone tested USB tethering and hotspot?
Would appreciate any useful information
Hey @Masttermind-wwww
When I got usb-moded working I went back and tested usb-moded-connection-sharing-android-connman-config (I think it was that package) and it was working.
I don’t usually have a use-case for needing usb tethering, so it’s not something I’ve used or tested since, but it can be done.
Wifi hotspot I have used marginally more regularly. It works too.
Thank you for your answer! Appreciate much
For those not following along the 10IV thread, there have been significant improvements over the last few weeks. This includes dual sim/esim support, calls in bluetooth, improved battery usage/life and storage encryption.
Essentially everything is working very well now. Thanks again to @Sharks and also now @Mister_Magister for the great improvements in the port.
Does the “Essentially everything is working […] now” also count for the 10 V? I don’t have so much time and only want to try it out when it has the potential to be a daily driver.
A huge thank you to @Sharks and @Mister_Magister also from my side!!
@juz is my 10 V tester! I don’t own a Zambezi :slightly_smiling_face:
He’s been regularly updating his post earlier in this thread - Lineage based port for Xperia 10 V (zambezi) - #6 by juz - as things change (thanks, man!)
Currently, based off his reports and my experiences on 10 IV, I believe the ports are equally functional and absolutely daily driver material.
