REPRODUCIBILITY: may have been one-time
OSVERSION: 5.0.0.55
HARDWARE: Jolla C2 - s19mps - s19mps - 1.0.0.40 - aarch64
REGRESSION: not specified
See Steps.
The system allows uninstallation of an important library.
After uninstallation, both zypper and pkcon, as well as ssu are broken due to missing library.
DO NOT DO THIS
pkcon remove libxml2
pkcon anything
zypper anything
ssu anything
EXPECTED RESULTS:
The attempt to remove the package should trigger the ‘this request will break your system’ message.
ACTUAL RESULTS:
Patchmanager: yes
OpenRepos: yes
Chum: yes
Other: none specified
Device Owner User: nemo
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.10.7
