Ahoy sailors!
I broke my Xperia X a few month ago and bought a second hand Xperia 10 II. I flashed it this friday with Kvarken 4.1.0. It’s so good to get back to Sailfish OS!
I struggle to synchronize my contacts and calendar using Microsoft Exchange.
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): Xperia 10 II
UI LANGUAGE: French
Data won’t synchronize from a Microsoft Exchange account.
Install the Microsoft Exchange app and set-up an account. The account creation is working, so I guess my credentials and settings are correct, plus I did that on my Jolla Phone, Jolla Tablet and Xperia X before.
- Go to Settings / Accounts / Microsoft Exchange
- From the pulley menu select Synchronize
Contacts and Calendar should be synchronized.
It’s not…
I tried to remove the Microsoft Exchange app, the account then starting over with the same result. After activating the developper mode, I checked journalctl while launching a new synchronization and got these warnings:
[C] unknown:0 - Library for the client "sailfisheas-contacts" does not exist
[W] unknown:0 - Failed to create client plug-in: "sailfisheas-contacts"
[W] unknown:0 - Failed to initialize client plug-in runner
[W] unknown:0 - Internal error, unable to start sync session for profile: "sailfisheas.Contacts-8"
[C] unknown:0 - Library for the client "sailfisheas-calendars" does not exist
[W] unknown:0 - Failed to create client plug-in: "sailfisheas-calendars"
[W] unknown:0 - Internal error, unable to start sync session for profile: "sailfisheas.Calendars-8"
I tried to remove then reinstall the calendar app to no end. I don’t know of any way to reinstall the contact app.
I checked the release notes’ known issues and the forum but found nothing related to this problem.
Does anyone encountered that and/or know how to solve it?
Regards.
A.
