Level indicator for the camera app
As the title suggests.
It would be nice to have some sort of graphic indication that you are holding the phone at a 0 angle when taking photos or videos.
Not a bad idea, I can normally guess roughly where level/upright is but to have an indicator would be useful.
Looking at an app by Poetaster called Spiritlevel (Openrepos), the cover shows something that could be miniaturised to fit the camera screen and act as a means of levelling. This could also be fudged in by patch or adding a file or two to the existing camera app. I don’t expect that this will be implemented by Jolla.
Was thinking the same thing, Spiritlevel is cool, and really quite neatly done.
Another idea would be to mimic the “Debugging Overlay” which shows framerate and rendering speed overlayed on the whole display.
A patch could do something similar, but only display it when the Camera is active. This way it would be available to any app that uses the camera, not just the ones to decide to implement that feature.
g5
Something like that as proposed design. (colours, size, position etc can vary depending on the implementation)
Primary and secondary theme colors to not be so obtrusive?
The basic idea is that the middle part moves according to the angle of the phone. When its level it changes to a different colour than when its not level.
Theme colours are fine.
I’ll kick it off with something you can paste into the following file;
devel-su nano /usr/lib64/qt5/qml/com/jolla/camera/capture/CaptureOverlay.qml
Paste it in underneath the last dollop of code at the bottom of said file.
The following code is taken/adapted from an app by Kimmoli called Inclinometer found in Jolla Store;
    ///// PASTE THE CODE UNDER THIS BIT
    ConfigurationValue {
        key: "/apps/jolla-camera/previousStoragePathStatus"
    Accelerometer {
        dataRate: 25
        active: Qt.application.state === Qt.ApplicationActive
        property double delta: 0.0
        property double rawAngle: 0.0
        property double angle: 0.0
        property double x: 0.0
        property double y: 0.0
        property double z: 0.0
        Behavior on x { NumberAnimation { duration: 175 } }
        Behavior on y { NumberAnimation { duration: 175 } }
        onReadingChanged: {
            x = reading.x
            y = reading.y
            var a
            if ( (Math.atan(y / Math.sqrt(y * y + x * x))) >= 0 )
                a = -(Math.acos(x / Math.sqrt(y * y + x * x)) - (Math.PI/2) )
            else
                a = Math.PI + (Math.acos(x / Math.sqrt(y * y + x * x)) - (Math.PI/2) )
            rawAngle = a * (180/Math.PI)
            angle = rawAngle + delta
    Item {
        anchors.centerIn: parent
        rotation: accelerometer.rawAngle
        Rectangle {
            color: "white"
            height: 10; width: parent.paintedWidth
        Rectangle {
            anchors.left: line.right
            color: line.color; height: line.height
            anchors.verticalCenter: line.verticalCenter
            width: Math.max(page.height, page.width)/20
        Rectangle {
            anchors.right: line.left
        OpacityRampEffect {
            sourceItem: lineLeft
            direction: OpacityRamp.LeftToRight
        OpacityRampEffect {
            sourceItem: lineRight
            direction: OpacityRamp.RightToLeft
    Item {
        z: -1
        anchors.centerIn: angleItem
        rotation: 90 - accelerometer.delta;
        Rectangle {
            color: "white"; height: 10
            width: angleItem.paintedWidth
        Rectangle {
            color: calibLine.color
            anchors.left: calibLine.right
            width: 120; height: calibLine.height
            anchors.verticalCenter: calibLine.verticalCenter
        Rectangle {
            anchors.right: calibLine.left
        OpacityRampEffect {
            offset: 0.25
            sourceItem: calibLineLeft
        OpacityRampEffect {
            offset: 0.25
            sourceItem: calibLineRight
    Image {
        width: 144; height: width
        rotation: accelerometer.angle
        source: "image://theme/icon-m-qr"
Looks something like the following (not a screenshot from camera, because file is overlay, so leveller does not show);
