hhead
1
BlitzMail provides two app icons. One for configuration (named “BlitzMail”) and another that allows quick sending of emails (named “BlitzNote”).
On Xperia X (Android 4 environment) both worked just fine.
On XA2 (new Android environment) BlitzNote doesn’t launch anymore.
Is there a way to get verbose debugging info?
So far I only tried this:
$ apkd-launcher de.grobox.blitzmail.apk de.grobox.blitzmail/de.grobox.blitzmail.NoteActivity
Launching Android Intent android.intent.action.MAIN de.grobox.blitzmail/de.grobox.blitzmail.NoteActivity
#(nothing happens)
hhead
2
Log Output:
164 500 I ActivityTaskManager: START u0 {act=android.intent.action.MAIN flg=0x10004000 pkg=de.grobox.blitzmail cmp=de.grobox.blitzmail/.NoteActivity} from uid 0
164 194 W WindowManager: TaskSnapshotSurface.create: Failed to find top fullscreen for task={taskId=197 appTokens=[AppWindowToken{4183277 token=Token{a55cc76 ActivityRecord{847a311 u0 de.grobox.blitzmail/.NoteActivity t197}}}] mdr=false}
333 333 D FakeHome: onPause
164 182 I SurfaceFlinger: ALIEN: discarding frame without app/window (system process).
1130 1152 I Adreno : QUALCOMM build : 1dcb581, I26dffed9a4
1130 1152 I Adreno : Build Date : 01/10/18
1130 1152 I Adreno : OpenGL ES Shader Compiler Version: EV031.22.00.01
1130 1152 I Adreno : Local Branch :
1130 1152 I Adreno : Remote Branch : refs/tags/AU_LINUX_ANDROID_LA.UM.6.4.R1.08.00.00.309.049
1130 1152 I Adreno : Remote Branch : NONE
1130 1152 I Adreno : Reconstruct Branch : NOTHING
1130 1152 I Adreno : PFP: 0x005ff087, ME: 0x005ff063
164 182 I chatty : uid=1000(system) SFThread identical 2 lines
1130 1130 W IInputConnectionWrapper: getTextBeforeCursor on inactive InputConnection
592 592 W RemoteKeyboard: Invalid editor state?
164 201 W system_server: Insufficient pre-allocated space to mmap vdex.
592 592 E RemoteKeyboard: ALIEN: Keyboard shown
hhead
3
Workaround:
In the file /usr/share/applications/apkd_launcher_de_grobox_blitzmail-de_grobox_blitzmail_NoteActivity.desktop replace the Exec line with this:
Exec=sh -c 'apkd-launcher de.grobox.blitzmail.apk de.grobox.blitzmail/de.grobox.blitzmail.MainActivity & sleep .1 && apkd-launcher de.grobox.blitzmail.apk de.grobox.blitzmail'
hhead
4
The workaround in my last post got cut off. Here’s the correct line:
Exec=sh -c 'apkd-launcher de.grobox.blitzmail.apk de.grobox.blitzmail/de.grobox.blitzmail.MainActivity & sleep .1 && apkd-launcher de.grobox.blitzmail.apk de.grobox.blitzmail/de.grobox.blitzmail.NoteActivity'
