Keyboard not showing up in specific case
REPRODUCIBILITY (% or how often): 100 %
HARDWARE (XA2, Xperia 10…): XA2
UI LANGUAGE: Norsk
When trying to enter some text in Duolingo app, the keyboard is showing up only for less than a second and cannot be launched for any longer.
Example screenshot: https://ibb.co/QX1k2d7
The same issue occurs in Duolingo when there are two text boxes to fill in. In general, for one small field the keyboard appears normally. In my case, Spanish course was taken (may be important, as the courses differ from each other significantly and may not be reproducible for others).
Sailfish OS 4.0.1.48, Android Support, Duolingo
Keyboard shows up when tapping text input box
Keyboard appears for a while and disappears
I can confirm this annoying glitch. However, I’m not sure how to provide more information or help debug this problem.
Experiencing exactly the same issue.
In some cases on Duolingo, the keyboard appears for less than 1 second.
Very frustrating, Duolingo is not usable anymore.
Have you tried upgrading Duolingo? It’s not happening to me anymore after an upgrade. I’m currently on 5.1.5.1115.
Indeed I haven’t seen the problem for a long time, so it’s probably solved.
