I installed MicroG (v/0.3.15) at first startup of my JP26, now I cannot uninstall it.
When uninstalling it from Jolla Store it shows uninstalled in the Jolla store, and “Allow MicroG” in AppSupport is unticked, but the app is still there. Fdroid also shows it as still installed.
Due to some problems I also experienced with MobilePay in my 10iii I wished to go back to an earlier MicroG version (v/0.3.10) but it is not possible since I cannot uninstall the one SFOS installed at startup.
Has anybody else seen this? Do anyone have a suggestion how to make SFOS uninstall the 0.3.15 version?
Maybe you could downgrade it in the F-Droid store, but for me I haven’t had any issues with the version of microG that comes with the JP2061, even with MobilePay. You just have to manually install MobilePay version 10.16.0 (4429694), because later versions have issues with device registration/PIN acceptance.
If you don’t know how to install certain version manually, you go to the MobilePay’s store page in the Aurora Store, hit the three dots in the top right corner, select “Manual download” and then enter the number 4429694 to the promt.
I have Mobilepay version 10.16.0 installed. I know this is the last version that work on 64bit phones.
(Mobilepay stopped releasing new versions for 32bit phones like XA2, at version 10.9.0)
My problem is that MicroG version 0.3.15 does not handle notifications correct. My JP26 worked fine (and I’m quite happy with it) for a week, I could make payments with Mobilepay without problems. But then I purchased something online, and the shop sent me a payment-request which never came through, then I tried to open Mobilepay, but it had crashed and now required re-installation.
In MicroG there is a setting allowing notifications to open the app, and this notification-system is not working properly in v/0.3.15, it crashes the app and leaves some garbage data requiring re-installation. I can re-install and it works fine until the next payment-request. I had the same problem in my 10iii and it was solved by going back to MicroG v 0.3.10.
In the place where I live we have an android doorbell-system, also here MicroG v/ 0.3.15 cannot open the app when a notification comes in. But MicroG 0.3.10 can.
It is not possible to uninstall the SFOS installed MicroG via Fdroid, it does not offer the option, and when it cannot be fully uninstalled it is not possible to install an older version.
Thank you both for your suggestions, it’s always nice with polite and relevant suggestions to a problem.
The 0.3.16 version is also not possible to install from Fdroid on top of the SFOS MicroG, and I do prefer to install from well known stores.
I was just really surprised that the uninstall functionality in the Jolla store actually do not uninstall the app. I seem to recall Jolla somewhere wrote it was possible to uninstall the MicroG they offer at startup.
I’m afraid for now I would have to do a factory reset and go through the whole setup again, without installing the SFOS offered MicroG, and then install MicroG from Fdroid.
Try a full reinstall of android support first, not sure if guides on the forum will be still applicable on 15 but the ones for XIII+ have a chance to work and get you at clean AAS state without losing all other data
Edit: see and the linked article Installing microG on Sailfish OS - #195 by fridlmue
You are right to be wary of where you install your applications, but in this instance the source is the MicroG github, so I’d say it should be OK.
The risk here lies in the prerelease either not having a fix, or having another regression that makes matters even worse, but given the alternative of reinstalling from scratch I thought it might be worth taking
Found out a way to remove microG - open the Jolla Store app and remove it from there (seems obvious don’t it?!).
You might have to stop and start AppSupport, and maybe remove the microG Settings app from the app drawer (hold down on the app drawer, then click x on the settings app) before cycling AppSupport again.
Following this I managed to install 3.0.14 on my JP
Nice to learn how you managed to uninstall MicroG and downgrade using the described procedure.
When the normal uninstall from the Jolla Store didn’t work I did not play around much more, I decided to do a factory reset, just to be sure there would be no incompatible files left behind.
I skipped the MicroG at SFOS startup and installed MicroG version 0.3.10 from Fdroid. The support function “MicroG Services Framework Proxy” Legacy support proxy library, could not be installed from Fdroid, it is listed as incompatible. But I understand this is only used for some old legacy systems which use a different method of notifications. Anyway things are like before on the JP26. Everything work except for the apartment block door phone system and MobilePay. So I gained nothing from downgrading MicroG.
Even though I now have the exact same setup as is working in my 10iii, MobilePay does not work, it can be installed and maybe be started once or twice but then it fails to start and suggest re-installation, it also fails if receiving a payment request.
So I did a lot of work for nothing by assuming that the same setup as in 10iii would work…
But on the positive side: factory reset worked just fine - and apart from the two (for me rather important apps) I am very pleased with my JP26 :-))
Thank you for reporting, I had thought of going through the hoops to get Mobilepay to be more stable, but now I know I shouldn’t Need to just move away from it, there was suggestion of Siirto. Might try that one next
I have blacklisted microG app in Aurora store to version 0.3.15.250932.250932030. And I don’t remember that I would have set it myself to blacklist. Is this correct or should we update it and how?
Aurora connects to the Google Play Store. If you don’t remember blacklisting it, It’s possible that Jolla configured this.
Anyway, you do not want to update these packages through Aurora, as they only host the actual Google packages not the microG packages that emulate them.
To update microG, you need to add their repo to Fdroid and update it from there.
