REPRODUCIBILITY: 100%
OS VERSION: SFOS 5.2.0.17
HARDWARE: Jolla Phone 2026
UI LANGUAGE: US EN
REGRESSION: don’t know
I recently activated automatic call recording in the system’s phone app.
The recording starts when a call is outgoing or incoming, after the call ends a notification shows up informing about the recording.
The list of recordings shows the correct date and the files are the right length in minutes and seconds, however nothing can be heard in them, not even at max volume and putting the speaker inside my ear.
When a call is incoming the vibration and ringtone can be heard at the start of the recording, once they stop (because I pick up the call) the playback plays complete silence.
This makes it seem like recording is fine as long as the phone rings, but mic and speaker get cut off as soon as I answer, of course I’m no expert so this is just a most likely wrong impression.
Audio recording via the audio recorder app works, audio recording via the camera app works, mic and speakers during calls work.
Tried restarting the phone and trying again to no avail.
Enable automatic call recording in the system app “phone”.
Enable android app support.
- Receive (or place) a call - receiving is better because you can hear the ringtone at the start of recording
- Make some noise
- End the call
- Reach the list of recorded calls (either via the notification or the phone app settings)
- Start playback of a call
Ability to hear the call
The call cannot be heard, only ringtone and vibration can be heard when receiving calls
FUTO Keyboard
Patch for switching to last used app by long edge drag
Chum, storeman
Microg, f-droid, aurora store
I opened this new topic because the ones I found were about hearing only one side or volume too low (I don’t hear anything after the ringtone)
