REPRODUCIBILITY: happened once so far
OS VERSION: 5.2.0.22 (Finlayson)
HARDWARE: Jolla Phone (2026), jp2601
UI LANGUAGE: Czech
REGRESSION: unknown
I tried to place a call in an area without usable coverage. The call attempt got stuck in “dialing” and the phone could not make any calls afterwards.
D-Bus state captured ~40 minutes after the attempt (dialed 16:50:46, captured 17:29):
org.ofono/ril_0 VoiceCallManager.GetCalls still listed /ril_0/voicecall02 with State “dialing”.org.nemomobile.voicecalllisted the same call with status 3 “dialing”, duration 0.- NetworkRegistration at capture time: registered, Technology “edge”; IpMultimediaSystem: Registered=false (no VoLTE).
Restarting voicecall-manager cleared the handler side, but ofono kept the “dialing” call. The call object finally disappeared on its own roughly 45 minutes after the dial attempt, and calling worked again without a reboot.
- Be in an area without usable coverage (phone fell back to 2G/EDGE, no VoLTE registration)
- Try to call someone
- The call attempt gets stuck in “dialing”
A call attempt that cannot be set up is terminated by a timeout within seconds, and the phone can dial again.
The call stays in “dialing” in ofono for tens of minutes; no outgoing calls are possible during that time.
ofono-1.29+git13.1-1.19.1, ofono-binder-plugin-1.1.28-1.16.1, ofono-vendor-mtk-radio-plugin-1.0.5, modem FW MOLY.NR17.R2.MP2.RC.RC2.SP.V18.4. Full D-Bus dump available on request.
