I messed up my Jolla 1 and had to reset it to factory, which I did.
Now, after performing all the updates until 3.4.0, I want to restore some data from the recovery mode (not while the phone is running).
My problem is that no matter what I do, I can’t get the shell in recovery mode as it’s always telling me that I have the Wrong code, try again although I know that I have the right one since it passes when I start normally.
I tried to reset it a few times and even went through Can't set new lock code - #13 by Sthocs to set back the original code I want to keep using but none worked in recovery.
I can unlock my phone just fine and I do have root access from FingerTerm with devel-su but I can’t access the shell from recovery mode.
Any idea on what I can do?
Note: I don’t know if it’s important but there is no SIM card in the phone since the reset.
