Well the device has arrived so time to install some apps…
Can get to the Store Front. Thereafter if I click on “Search” - pull the screen down to get there, I get “Store is not responding”
Same if try to install ANY app (to test)
This is not so much the store itself but the device (I suppose this is about the C2), for some reason it sometimes decides to hang for ages as soon as you dare to open a pull-down menu in any app. If you let it sit for a while, the problem will fix itself.
I’m sorry but you are wrong in this case.
Jolla store tells me it is installed but there are no extra apps on the device itself.
The way to correct this seems to be to uninstall the app and reinstall it in case someone is having a similar problem.
Yes a C2 - I’m beginning to wonder what exactly the “C” stands for
Some part of your post must not have come through, then, because the first post only mentions the “Store is not responding” problem.
